Is the Closure of a Totally Bounded Set Also Totally Bounded?
  • Thread starter Thread starter sazanda
The discussion revolves around the properties of totally bounded sets within the context of complex analysis. The original poster (OP) is exploring the relationship between a set being precompact and its closure being compact.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants are questioning the definitions of precompactness and total boundedness, with some suggesting that the OP may be conflating the two concepts. There are attempts to clarify the definitions and explore the implications of these properties in the context of the closure of sets.
There is an ongoing exploration of definitions and properties related to totally bounded sets. Some participants have provided guidance on proving that the closure of a totally bounded set is also totally bounded, while others are seeking clarification on the definitions and the appropriate approach to take.
Participants note that the OP has not covered the concept of total boundedness in their studies, leading to discussions about relying on definitions of precompactness instead. There is also mention of using the Heine-Borel theorem in the context of the discussion.
sazanda
Let S be a subset of C. Prove that S is precompact if and only
if S(closure) is compact.
I have already showed if S(closure) compact, then S is precompact
how can I show if S is precompact, then S(closure) is compact?
What is your definition ofS being precompact? The one I knew is that the closure of S is compact.
I think the OP means totally bounded. I've seen this terminology used before...
Anyway, you are working in [itex]\mathbb{C}[/itex]. So try to prove that the closure of a totally bounded set is (totally) bounded. Then use Heine-Borel.
Definition:
A set S is precompact if every ε>0 then S can be covered by finitely many discs of radius ε .
We didn't cover totally boundedness. I think we should use definition of precompactess.
Sazanda:
The definition you gave is the same as that of totally-bounded. I mean, totally.
totally bounded
how Can I show that the closure of a totally bounded set is (totally) bounded?
solution Tried:
Assume S is totally bounded. then for very ε>0 there are finitely many discs (O=Union of finitely many discs) that covers S let x be a limit points of S that is in S closure. but not in S.
hence x is in O (how can I show this?)
So x is in O for all x in S closure.
Hence S closure is totally bounded.
Am I on the right track?
  • · Replies 16 ·
