CarlB said:
Now the thing that is interesting is that so long as we restrict ourselves to only two different directions, we can get by with real multiples. But when we go to three different directions, perhaps we might call them R, G and B, then the reduction factor can become complex.
For example, consider the Pauli case and three Stern-Gerlach apparata with orientations of x, y and then z. The density matrix for the overall experiment is given by the product of the three projection operators:
[tex]P_x\;P_y\;P_z[/tex]
[tex]=(1+\sigma_1)(1+\sigma_2)(1+\sigma_3)/8[/tex]
[tex]= (1+\sigma_1+\sigma_2+\sigma_3 +i\sigma_3 +i\sigma_1 -i\sigma_2 +i\sigma_3\sigma_3)/8[/tex]
[tex]= \frac{1+i}{2} (1+\sigma_1)(1+\sigma_3)/4[/tex]
[tex]= \frac{1+i}{2} P_x \; P_z[/tex]
In other words, we can again write the product of the idempotent matrices as a product where we include only the first and last matrices. All the idempotents that show up in the middle get turned into just a complex constant that factors out.
The same calculation obtains if one uses the gamma matrices, but the factor may be a bit more complicated than just a complex number. Depending on how one embeds SU(2) in the Dirac algebra, one can end up with several different possibilities for the "i". For example, one might wish instead to use an embedding which gave [tex]\gamma_0[/tex] instead of i. If this sort of thing happens, then it turns out that whatever thing we end up that is more complicated than i will nevertheless commute with our surrounding idempotents.
In other words, it really is the case that a sequence of Stern-Gerlach apparata can be reduced to just the first, last, and a phase multiplication, and this is the case even when we assume Stern-Gerlach apparata that can separate arbitrary isospin. The freedom to embed SU(2) in several different ways corresponds to a freedom to assume Stern-Gerlach apparata that measure isospin, spin and or various combinations.
Now the reason that this is particularly interesting is that it shows a place where one can extract complex numbers from QM in a manner that is not simply a result of our use of spinors. That is, we get complex numbers even within the density matrix formalism, and not only that, but they show up in the density matrix formalism without any need to deal with wave functions that depend on position. The reason this is important is that it gives us a way of distinguishing between the complex phases that are just phases and that go away in a density matrix formulation, and the complex phases that allow quantum waves to intefere with themselves.
I should mention that the whole concept of the Schwinger measurement algebra seems to be to associate the elementary particles with our representations of the measurements that define them. That this would produce a formalism that has less garbage (i.e. nonphysical phase degrees of freedom) than the spinors is interesting to me.
Carl
