Is the divergence of the Dirac-delta function truly zero at the origin?
  • Thread starter Thread starter brianparks
    Function
The discussion centers on the divergence of the vector field v = 1 / r^2 r, which is directed radially outward. Despite the expectation of a large positive divergence, calculations show that the divergence is zero for r > 0. Participants express confusion over whether the weakening of the field as one moves away from the origin indicates a negative divergence. Clarifications reveal that the divergence is indeed zero everywhere except at the origin, emphasizing that the field does not diverge in the radial direction. This highlights a common misunderstanding of divergence in relation to vector fields.
brianparks
In introducing the dirac-delta function, my electrodynamics discusses the following function:
v = 1 / r^2r
The text states that "at every location, v is directed radially outward; if there ever was a function that ought to have a large positive divergence, this is it. And yet, when you actually calculate the divergence (using Eq. 1.71), you get precisely zero."
At least on the positive portion of the x-y-z axis, it seems to me that v would have a negative divergence, meaning that as you move away from the origin, the magnitude of the vectors (which all point radially outward from the origin), would get smaller. That is, for every point other than the origin, the amount going in would exceed the amount coming out (the definition of a sink). For example:
Origin---------->-------->------>---->-->
Does this not indicate a negative divergence?
This question has caused me to wonder if my understanding of the divergence function is flawed.
Any help is greatly appreciated,
--Brian
The divergence is zero for r > 0 because the field never diverges from the radial direction.
But doesn't the field weaken as you move radially outward? If so, wouldn't that mean that the divergence is negative?
Maybe my understanding of divergence is wrong.
Consider this function:
v = 1 / x^2x
From 0 to infinity, it would look like this:
and so on...
Wouldn't it have a negative divergence?
Thanks again for any help,
--Brian
v = 1 / x^2x
and so on...
--Brian
See http://hyperphysics.phy-astr.gsu.edu/hbase/diverg.html#c3
for the appropriate formulas for divergence in spherical coordiantes.
v = 1 / r^2r
--Brian
Let us try.
\Vec{v}(x,y,z)=\frac{1}{x^2+y^2+z^2}(x\Vec{i}+y\Vec{j}+z\Vec{k})
\frac{\partial v_x}{\partial x} =-\frac{2x^2}{(x^2+y^2+z^2)^2}+\frac{1}{x^2+y^2+z^2}= \frac{-2x^2}{r^4} + \frac{1}{r^2}
In the same way,
\frac{\partial v_y}{\partial y} =-\frac{2y^2}{r^4}+\frac{1}{r^2}
and
\frac{\partial v_z}{\partial z} =-\frac{2z^2}{r^4}+\frac{1}{r^2}
The divergence is
\mbox{Div}(\Vec{v})=\frac{\partial v_x}{\partial x} +\frac{\partial v_y}{\partial y} +\frac{\partial v_z}{\partial z}=
=\frac{-2x^2-2y^2-2z^2}{r^4}+\frac{3}{r^2}=\frac{-2r^2}{r^4}+\frac{3}{r^2}=\frac{1}{r^2}
It is the function
\Vec{v}(\Vec{r}) = \frac{\Vec{r}}{r^3}
whose divergence is zero everywhere except at the origin.
ehild
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
I am attempting to use a Raman TruScan with a 785 nm laser to read a material for identification purposes. The material causes too much fluorescence and doesn’t not produce a good signal. However another lab is able to produce a good signal consistently using the same Raman model and sample material. What would be the reason for the different results between instruments?
