- 3,285
There is a misunderstanding here, let me see if I can clear it up.binis said:With all my respect,you undoubtfully know that we are referring to a regular plane.
I am afraid that only you are referring to a 'regular plane', because nobody else understands what that means. The other posters on this thread are referring to all 2-dimensional geometries where Euclid's first four axioms hold. Such geometries are referred to as geometries of constant curvature and can be divided into three groups:
- Euclidean geometry, which is defined as the geometry of constant curvature with the axiom "given any straight line and a point not on it, there exists one and only one straight line which passes through that point and never intersects the first line, no matter how far they are extended", in other words the parallel postulate is true
- Elliptic geometries, which are defined as geometries of constant curvature with the axiom "given any straight line and a point not on it, there does not exist any straight line which passes through that point and never intersects the first line, when they are both extended without bound", so the parallel postulate does not hold
- Hyperbolic geometries, which are defined as geometries of constant curvature with the axiom "given any straight line and a point not on it, there may exist more than one straight line which passes through that point and never intersects the first line, no matter how far they are extended", so again the parallel postulate does not hold.
As you are claiming a proof of the parallel postulate, then you must be referring to Euclidean geometry (because in non-Euclidean geometry the parallel postulate is false). You must also be inferring some other definition of Euclidean geometry, otherwise the parallel postulate is an axiom not a theorem and doesn't need to be proved. From your post
you have assumed that you can draw a unique line from a point A intersecting a line β at right angles. This is an alternative axiom that defines Euclidean geometry, and your proof is correct.binis said:Nevertheless,you can prove it otherwise:draw the unique vertical line β from the point A to the line α.Then draw the unique line γ vertical to β at the point A.The line γ is parallel to α and it is the unique.Do I use any axiom?
It is also possible to define Euclidean geometry with many other axioms instead of the parallel postulate including the equidistance postulate, Playfair's axiom, Proclus' axiom, the triangle postulate, and the Pythagorean theorem. In each case it is possible to prove the parallel postulate using that axiom together with Euclid's first four axioms.
In conclusion, as in many misunderstandings, it could be said that you are right, and so is everybody else.
You are right that in what you call a 'regular' plane (perhaps 'flat' would be a more commonly understood term), which is properly called a 2-dimensional Euclidean geometry the parallel postulate is provably true. You have presented an example of such a proof using the assumption of the existence of a unique perpendicular, which is provably true in Euclidean geometry.
Everybody else is right that you cannot prove the parallel postulate using only the first four axioms because non-Euclidean geometries exist where the first four postulates are axioms and the parallel postulate is provably false.
