Is the force that keeps the Earth spinning
The discussion clarifies that there is no specific force keeping the Earth spinning; rather, it is inertia that maintains its rotation at a constant rate. The Earth's rotation is influenced by gravity, which also causes tidal bulges that affect the Moon's orbit. The Moon gradually moves away from Earth due to the gravitational interaction between the tidal bulge and the Moon, which gives the Moon energy to ascend into a higher orbit. Additionally, while the Earth spins, points on its surface experience acceleration due to the change in direction, but this does not imply a force is acting to maintain the spin. Overall, the interplay of inertia and gravity is crucial to understanding Earth's rotation and the Moon's movement.
quincy harman
Is the the force that keeps the Earth spinning the same force that moves the moon farther away from us? Spinning objects are accelerating and it takes a force to accelerate an object so the force that keeps the Earth spinning is centrifugal force right?
There is no "force that keeps the Earth spinning" because the Earth spins at a constant rate (to a very good approximation).
Not if they spin at a constant angular velocity.
Points on the object are accelerating - but Earth is held together by gravity.
The tides induced by the moon slow down the rotation frequency a tiny bit, and they also move the moon outwards very slowly.
so it's a combination of centrifugal force and gravity? and if you're spinning at a constant speed but changing direction that is acceleration right?
On the surface of Earth you feel both together, yes. Gravity is much stronger.
That depends on what you mean with "acceleration". The individual parts of you are accelerating, but I would not say you as a whole are accelerating.
An object on the surface of the Earth is moving at a constant speed and it's direction is changing so yes the object is accelerating. The force that causes it to accelerate is gravity. Without gravity the object would move in a straight line and fly off the Earth at a tangent to the surface.
Is the force that keeps the Earth spinning the same force that moves the moon farther away from us?
There is no "force" that keeps the Earth spinning. It's inertia that keep it spinning.
The reason the moon is moving further away from us is quite complicated. The moon has gravity which causes a tidal bulge on earth. A combination of the Earth's rotation and friction means the tidal bulge isn't directly below the moon, but slightly ahead or leading the moon. The gravitational pull between the tidal bulge and the moon cause the moon to gain energy and move into a higher orbit. It's a bit like swinging a ball on a string around your head...by moving your hand around in a circle slightly ahead of the ball you can make it go faster.
Likes quincy harman
But it has it is constantly changing direction and it takes force to change direction and what is a tidal bulge is the Earth actually misshaped by the moon?
The centripetal force is perpendicular to the direction of motion, so it (gravity) is a force that holds the Earth together, not a force that changes or works to maintain the rotation rate.
The Earth has non-zero angular momentum, which causes the Earth to rotate. Momentum is always conserved, so unless a significantly strong force acts on Earth, its rotational rate will remain more or less constant.
quincy harman said:
But it has it is constantly changing direction and it takes force to change direction..
Velocity has components speed and direction. In the context of the moon... Inertia ensures the speed stays constant. Gravity ensures the direction changes.
The most noticeable and significant effect are the water tides (many meters in height) but yes the solid surface of the Earth is also distorted (about 40cm)..
http://en.wikipedia.org/wiki/Earth_tide
Likes quincy harman
and how does gravity change the shape of Earth?
It keeps Earth in the approximate shape of a sphere.
Google is your friend..
http://en.wikipedia.org/wiki/Tide
Because the gravitational field created by the Moon weakens with distance from the Moon, it exerts a slightly stronger than average force on the side of the Earth facing the Moon, and a slightly weaker force on the opposite side. The Moon thus tends to "stretch" the Earth slightly along the line connecting the two bodies.
I'm referring to the tidal bulges.
sorry i didn't see that
Thank you for the help.
