Is the Hydrogen Atom Ground State Wave Function Normalized?
3 replies · 25K views · last reply
jg370
The ground state wave function for the electron in a hydrogen atom is:
[tex]\psi(r) = \frac{1}{\sqrt (\pi a_o^3)} e^\frac{-r}{a_o}[/tex]
where r is the radial coordinate of the electron and a_o is the Bohr radius.
Show that the wave function as given is normalized.
Any wave function satisfying the following equation is said to be normalized:
[tex]\int_{-\infty}^{+\infty} |\psi|^2\dx = 1[/tex]
Because the sum of all probabilities over all values of r must be 1,
[tex]\int_{-\infty}^{+\infty} (\frac{1}{\sqrt (\pi a_o^3)} e^\frac{-r}{a_o})^2 dr = \frac{1}{\pi a_o^3} \int_{-\infty}^{+\infty} e^\frac{-2r}{a_o^2} dr = 1[/tex]
Since the integral can be expressed as the sum of two integrals, we have,
[tex]\frac{1}{\pi a_o^3} \int_{-\infty}^{+\infty} e^\frac{-2r}{a_o^2} dr = \frac{2}{\pi a_o^3} \int_0^{+\infty} e^\frac{-2r}{a_o^2} dr = 1[/tex]
After integrating, I obtain,
[tex]\frac{1}{\pi a_o^3} = 1[/tex]
which is definitely incorrect. However, I do not see any other way to proceed. could someone give some assitance.
Thanks for your kind assistance
jg370
you integrated wrong -
[itex]\int_0^{\infty} e^{-\frac{2r}{a_0^2}} dr = [-\frac{a_0^2}{2} e^{-\frac{2r}{a_0^2}]_0^{\infty}=\frac{a_0^2}{2}[/itex]
which gives [itex]\frac{1}{2 \pi a_0}=1[/itex]
the a_0 in your exponent shouldn't be squared, also the normalization condition says you should integrate over the bounds of your function. if r is the radial coordinate then how can it have a value of negative infinity? similarly your no longer normalizing in 1-d but 3D I recommend using spherical coordinates in which case your integral inherits a r^2 sin theta
