Is the Reduction Formula Valid for All n in Integral Calculations?
  • Thread starter Thread starter jimbobian
    Formula Reduction
The discussion revolves around the validity of a reduction formula for the integral \( I_n = \int_0^\infty \frac{1}{(1+x^2)^n} \, \mathrm{d}x \). Participants are exploring the conditions under which the formula \( 2nI_{n+1} = (2n-1)I_n \) holds true, particularly focusing on the range of values for \( n \) that ensure convergence of the integral.
  • Participants discuss the convergence of the integral for different values of \( n \), with some suggesting that \( n > 0 \) is necessary while others reference a requirement of \( n > \frac{1}{2} \). There are attempts to derive the reduction formula using integration by parts and to clarify the implications of specific values of \( n \) on convergence.
The conversation is ongoing, with participants providing insights and posing questions about the conditions for convergence. Some guidance has been offered regarding the evaluation of the integral and the implications of certain values of \( n \), but no consensus has been reached on the exact range of validity.
Participants are considering the behavior of the integral as \( n \) approaches specific values, particularly \( n = 1 \) and \( n = \frac{1}{2} \), and questioning the assumptions made regarding convergence and the validity of the reduction formula.
jimbobian
If In denotes [tex]\int_0^∞ \! \frac{1}{(1+x^2)^n} \, \mathrm{d} x[/tex]
Prove that [itex]2nI_{n+1} = (2n-1)I_n[/itex], and state the values of n for which this reduction formula is valid.
[tex]I_n=\int_0^∞ \! \frac{1}{(1+x^2)^n} \, \mathrm{d} x[/tex]
[tex]=\int_0^∞ \! (1+x^2)^{-n} \, \mathrm{d} x[/tex]
By parts:
[tex]=\left[ x(1+x^2)^{-n} \right]_0^∞ + 2n\int_0^∞ \! \frac{x^2}{(1+x^2)^{n+1}} \, \mathrm{d} x[/tex]
[tex]=0 + 2n\int_0^∞ \! \frac{(1+x^2)-1}{(1+x^2)^{n+1}} \, \mathrm{d} x[/tex]
[tex]=2n\int_0^∞ \! \frac{(1+x^2)}{(1+x^2)^{n+1}} \, \mathrm{d} x - 2n\int_0^∞ \! \frac{1}{(1+x^2)^{n+1}} \, \mathrm{d} x[/tex]
[tex]=2nI_{n}-2nI_{n+1}[/tex]
[tex]2nI_{n+1}=(2n-1)I_{n}[/tex]
as required.
It's the next bit where I'm stuck - the range of values for which n is valid. Obviously when part of the integral has been evaluated (following parts), this requires that n>0 otherwise the expression doesn't converge. I can't see anywhere else in the method where there is a restriction for n to be a specific value so I went with n>0 as my answer, but my book says n>1/2, can anyway shed some light on this for me.
Thanks
the expression inside the integral is always positive and so does the integral.at n=1/2 the integral does not converge and observe that at n=1/2 ,I(n+1) is zero and for 0<n<1/2, I(n+1) is negative.
you should use:
[tex] \frac{1}{(1 + x^2)^n} = \frac{1 + x^2 - x^2}{(1 + x^2)^n} = \frac{1}{(1 + x^2)^{n - 1}} - \frac{x^2}{(1 + x^2)^n}[/tex]
For the integral of the second term, use integration by parts:
[tex] -\int_{0}^{\infty}{x \, \frac{x}{(1 + x^2)^n} \, dx}[/tex]
[tex] u = x \Rightarrow du = dx[/tex]
[tex] dv = \frac{x}{(1 + x^2)^n} \, dx \Rightarrow v = \int{ \frac{x}{(1 + x^2)^n} \, dx} \stackrel{t = 1 + x^2}{=} \frac{1}{2} \, \int{t^{-n} \, dt} = \frac{t^{1- n}}{2(1 - n)} = -\frac{1}{2 (n - 1) (1 + x^2)^{n - 1}}[/tex]
Combine everything, identify the relevant integrals with [itex]I_n[/itex], and [itex]I_{n - 1}[/itex], and see what you get.
Oh, I see you already did the steps. As for the range of validity, answer these questions:
1) What is the value of the integral [itex]\int{t^{-n} \, dt}[/itex] for [itex]n = 1[/itex]?
2) When does the integrated out part [itex]\frac{x}{2(n - 1)(1 + x^2)^{n - 1}}[/itex] converge when [itex]x \rightarrow \infty[/itex]?
2) When does the integrated out part [itex]\frac{x}{2(n - 1)(1 + x^2)^{n - 1}[/itex] converge when [itex]x \rightarrow \infty[/itex]?
Please preview your posts, LaTeX errors happen all the time.
Thanks for your response.
1) ln(t), so this would suggest it doesn't converge for n=1?
2) Firstly I'm not sure where you've got this fraction from, I can't find it in any working of yours or mine? It would converge for n>1 for sure. For n=1 it won't converge, but for n<1 I have no idea?
what is [itex]u v[/itex] in the integration by parts?
  • · Replies 105 ·
13K
