Is the Setup for the Electric Scaler Potential Integral Correct?
7 replies · 2K views · last reply
kosmocomet
66e3b29a-566a-4e53-b5cb-82d593a806dd
Diagram of a uniformly charged circular disk of radius a with surface charge density ρs, viewed in perspective; point P(0,0,h) lies on the z-axis above its center, with a thin ring of radius r and width dr marked, labelled dq = 2πρs r dr.
  • V=¼*(1/(π∈) * ∫(ρs/(R')*ds' where R' is distance from point to surface
  • R'=|R-Ri| distance from observation point to location of surface charge density.
So my attempt was to define R' as R'=√((-r)2+(-Φ)2+(z)2). Then I said that ds' is = rdrdΦ. I put this into the integral. I am confused since the integral looks very involved ad wanted to know if my set up was correct.
Any help is much appreciated.
  • Diagram of a uniformly charged circular disk of radius a in the xy-plane with surface charge density ρs, a point P(0,0,h) on the z-axis, and a ring of width dr at radius r labeled dq = 2π ρs r dr.
  • Diagram of a uniformly charged circular disk of radius a with surface charge density ρs, viewed in perspective; point P(0,0,h) lies on the z-axis above its center, with a thin ring of radius r and width dr marked, labelled dq = 2πρs r dr.
Why do you define R' that way?
Thanks for the response. I am using cylindrical coordinates and since the point P is (0,0,z) and the disk is(r,Φ,0) doing the substraction is -r,-Φ,z whcih is the vector R'. The magnitude is then R'=√((-r)2+(-Φ)2+(z)2).
OK. I see how you did it, but it is not correct. For one thing it is dimensionally inconsistent. It does not make sense to add ##rad^2## to ##m^2##. Let's approach it another way. Let r and z be constant and consider two angles, ##Φ_1 = 0## and ##Φ_2 = π/2##. Is the distance R' different for the different values of ##Φ##?
Well...I guess not mow that I think about it. Since, the distance would be based on r and z, correct?
If this is true, would the surface integral be drdΦ or dΦdz? I think it would be drdΦ since it is defined in radial and angular direction. The surface, I mean.
Yes.
That's close, but what is the differential area in polar coordinates?
