Is the speed of light the same for all observers?
The discussion revolves around the question of whether the speed of light is the same for all observers, regardless of their motion. Participants explore the implications of this statement within the context of special relativity and the nature of velocity addition.
  • Some participants assert that the speed of light is constant at 299,792,458 m/s for all observers, regardless of their relative motion.
  • Others express confusion about how the speed of light can remain constant when their understanding of motion suggests otherwise, particularly in relation to the perceived speed of moving objects.
  • A participant explains that the addition of velocities does not follow classical rules when speeds approach that of light, referencing a specific formula for relativistic velocity addition.
  • Some participants note that the misunderstanding stems from applying Galilean transformations, which are only valid for speeds much smaller than the speed of light.
  • There is mention of the lack of a definitive explanation for why the speed of light is constant in all reference frames, with some suggesting it may relate to conservation laws or the wave nature of matter.
  • One participant requests clarification on mathematical terms used in the discussion, indicating a need for further explanation of the relativistic velocity addition formula.
Participants generally agree that the speed of light is constant across reference frames, but there is disagreement regarding the implications of this constancy and the understanding of velocity addition. The discussion remains unresolved on the deeper reasons behind this phenomenon.
Some participants express uncertainty about the accuracy of external sources referenced in the discussion, and there are limitations in understanding the mathematical expressions used, which may affect the clarity of the arguments presented.
Dewbo
Is this statement true? The speed of light (about 300,000,000 meters per second) is the same for all observers, whether or not they're moving.
If so could someone please explain it to me, because it was my understanding that if an object was moving at a constant velocity it would appear to be traveling slower to an observer which is stationary than an observer traveling at any constant velocity.
Found on http://science.howstuffworks.com/warp-speed2.htm
Thanks
Thanks
I didn't see anything in that link that says that light or anything else "would appear to be traveling slower to an observer which is stationary than an observer traveling at any constant velocity". Can you please copy and post the text in that link that says anything like that?
The statement is false. The speed of light is constant (299,792,458 m/s) regardless of reference frame and velocity of an observer.
That wasn't a quote, that was what I thought, as i said "because it was my understanding that...".
read the question more thoroughly please.
But then you put a link right after that statement. It is naturally implied that you learned that from that link!
So you need to thoroughly read your post and make sure you convey your message clearly.
IF that link wasn't your reference, what is the purpose for it being presented there?
Zz.
This doesn't answer my question you just re quoted the statement with a more accurate speed of light and different context.
That statement is true (aside from AmanDhaliwal's point about it being 299,792,458 m/s instead of "about 300,000,000" m/s).
Your understanding is wrong - speeds do not add and subtract that way. Let's say that you're at rest, somebody ("Slowguy") passes by you at speed u; and then a moment later "Fastguy" moving at some faster speed v passes by you in the same direction. You're expecting that Fastguy's speed relative to Slowguy will be (v-u). It's not; it's [tex]\frac{v-u}{1-\frac{uv}{c^2}}[/tex]
Two interesting things about this formula:
1) For speeds that are small compared with the speed of light, it comes out REALLY close to the v-u that you expected; that's why you've never noticed.
2) If v=c (that is, fastguy is actually a pulse of light) the formula comes out to give fastguy moving at speed c relative to both you and slowguy, which makes the statement that you found on the web consistent.
In a way, it did answer your question. It is one of the fundamental postulate of SR that the speed of light is a constant in ALL reference frame.
The reason why you think it might move slower is because you are using what we call "Galilean transformation", i.e. the way we add velocities. It has already been shown that this is only valid for velocity that is very much smaller than c, i.e. an approximation.
If you start with the postulate of SR, then there is a more generalized way to add velocities. If you are asking WHY c is a constant in all reference frames, we have no answer to that (yet), because that is how Nature behaves as we know it now.
Zz.
Thanks
That site is inaccurate, but it does explain the basics. Not clear enough? Regretfully I don't understand your (mis)understanding about observing a moving object, or what that has to do with the speed of light. No object can reach the speed of light.
Ahh I see, so no one knows why it happens but we just have to accept that it's true.
Thank you for you help.
Dewbo said:
Ahh I see, so no one knows why it happens but we just have to accept that it's true. [..]
Different people give different answers as to the "why". For example, assuming that Maxwell's electrodynamics is correct then it has been shown that special relativity (incl. the aspect that you mentioned) follows from the conservation laws (conservation of momentum and energy). Perhaps it can also be shown to follow from the wave nature of matter (I'm not sure about that one).
Could you please expand on the equation, I'm not familiar with the terms "tex" and "frac".
What you should see is something like:
v - u
1 - uv/c2
If you see terms like "tex" and "frac", then there is a problem with your browser or internet reception.
See here:
http://hyperphysics.phy-astr.gsu.edu/hbase/relativ/einvel.html
There's also Wikipedia, but it probably has more "extra" stuff than you really want:
http://en.wikipedia.org/wiki/Velocity-addition_formula
As Harrylin noted, your browser isn't decoding LaTeX code for you for some reason. If you're going to hang around here a lot, you really should get that fixed, because we use LaTeX a lot for equations. Try asking about it in "Forum Feedback and Announcements", down at the bottom of the list of forums on our home page.
I believe MathJax doesn't work in tapatalk.
  • · Replies 33 ·
  • · Replies 22 ·
  • · Replies 34 ·
  • · Replies 57 ·
  • · Replies 25 ·
