Is the Summation Converging in the Given Interval?
6 replies · 2K views · last reply
Kernul
I'm give the following summation of functions and I have to see where it converge.
$$\sum_{n = 1}^{\infty} \frac{(3 arcsin x)^n}{\pi^{n + 1}(\sqrt(n^2 + 1) + n^2 + 5)}$$
Putting ##3 arcsin x = y##, I already see that with the theorem of D'Alambert I have a range ##r = \pi##.
The summation then converges in the interval:
$$|3 arcsin x| < \pi$$
which is
$$sin(-\frac{\pi}{3}) < x < sin(\frac{\pi}{3})$$
Now I don't know it the summation converges in the two external points, so I try with the first one and I get:
$$\frac{1}{\pi}\sum_{n = 1}^{\infty} \frac{(-1)^n}{(\sqrt(n^2 + 1) + n^2 + 5)}$$
In this case, I decide to use the Leibniz criterion. So first I find if the summation converges to ##0## and then I find if decreases monotonically.
Doing the limit of the summation (minus the ##(-1)^n##) I get that it converges to ##0##.
Now, to find out if it decreases monotonically, I do the first derivative of the following:
$$f(n) = \frac{1}{(\sqrt(n^2 + 1) + n^2 + 5)}$$
and I end up with
$$f'(n) = -\frac{\frac{x}{\sqrt(x^2 + 1)} + 2x}{(\sqrt(n^2 + 1) + n^2 + 5)^2}$$
Now I have to put this ##>0## but due to the minus sign it will be ##<0##. The one at the denominator is always positive, so we have to look at only the numerator. We will have then:
$$\frac{x}{\sqrt(x^2 + 1)} + 2x < 0$$
But, strangely, I don't get how to continue from here.
Can someone help me?
##x \mapsto \frac{x}{\sqrt{x^2+1}}+2x## is positive for ##x>0##, negative for ##x<0## and zero at ##x=0##.
I do not understand how differentiating f(n) wrt n caused x to appear from nowhere.
Since 1/n2 converges, it is rather obvious that the sum you have converges at both ends of the range. Is there not a test along those lines?
which is
You have ##f(n) = 1/d(n)##, where ##d(n) = \sqrt{n^2+1} + n^2+5## is a strictly increasing function of ##n##. No calculus is needed here: ##n^2## is increasing in ##n##, so ##\sqrt{n^2+1}## is increasing, as is ##n^2+5##. You are just adding two increasing functions.
Why? How did you do that?
Sorry, my bad! I meant "n" where there was "x".
So it decreases monotonically? This means that both this and the other one for ##\frac{\pi}{3}## converge and so it all converges to the interval ##[-\frac{\pi}{3} , \frac{\pi}{3}]##?
Kernul said:
Why? How did you do that?Sorry, my bad! I meant "n" where there was "x".So it decreases monotonically? This means that both this and the other one for ##\frac{\pi}{3}## converge and so it all converges to the interval ##[-\frac{\pi}{3} , \frac{\pi}{3}]##?
Why do you assume you have convergence at both end points?
##\frac{x}{\sqrt{x^2+1}}+2x=x \cdot \underbrace{(2+\frac{1}{+\sqrt{x^2+1}})}_{>\,2}##
