Is the supremum of [-r,r] always equal to r or -r?
  • Context: Undergrad
  • Thread starter Thread starter AKBAR
    Confused Supremum
The supremum of the function defined as f(x) = (n-1)! / (1+x)^n over the interval [-r, r] is determined by the behavior of the function rather than the interval endpoints alone. For 0 < r < 1, if f is increasing, then the supremum is f(r). However, if f is decreasing, the supremum shifts to f(-r). For example, with r = 0.5, the supremum is f(0.5) = (n-1)! / (1-0.5)^n. The context of the function and its properties significantly influence the supremum value.
  • Understanding of supremum and least upper bound concepts in real analysis.
  • Familiarity with function behavior, specifically increasing and decreasing functions.
  • Knowledge of Taylor series and radius of convergence.
  • Basic calculus, including differentiation and function evaluation.
  • Study the properties of increasing and decreasing functions in real analysis.
  • Learn about Taylor series and their convergence properties.
  • Explore examples of supremum calculations for various types of functions.
  • Investigate the implications of function behavior on optimization problems.
Mathematicians, students of calculus and real analysis, and anyone studying optimization and function behavior in mathematical contexts.
AKBAR
Let 0 < r < 1. Then \sup_{x\in[-r,r]}f(x)=f(r)}, right? However, the text I'm reading says it's f(-r). How could this be? For example, say r = 0.5, then the least upper bound of [-0.5, 0.5] is 0.5, or r, right? I don't see how it could be -r. Thanks for any help.
Hi AKBAR! :smile:
No.
That will be true if f is increasing in [-r,r], but not in most other cases.
What is f? What is the relevance of 0 < r < 1? What is the context? :confused:
You are taking the supremum ("least upper bound") of the values of f not x!
For example, if f(x)= x, then f(-r)= -r, f(r)= r and f takes on all values between -r and r. In that case the sup of f(x) on the interval (not the sup of the interval itself) is f(r).
But if f(x)= -x, then f(-r)= r, f(r)= -r and now the supremum occurs at -r: f(-r) is the largest value (in fact it is the maximum value).
And it can get more complicated than that. If f(x)= -x2, then f(-r)= f(r)= -r2< 0. The maximum (and so sup) occurs in the middle of the interval. The sup is f(0)= 0.
Ahhhh...that really clears things up. Thank you guys.
The function in question was f(x)=\frac{(n-1)!}{(1+x)^n}. So \sup_{-r\leq x\leq r}\frac{(n-1)!}{(1+x)^n}=\frac{(n-1)!}{(1-r)^n} The r comes from the radius of convergence of a Taylor expansion (I'm reading about where T(x) = f(x) ).
Thanks again for the help.
