Is the Transpose Conjugate of a Unitary Matrix Equal to the Identity Matrix?
  • Context: Undergrad
  • Thread starter Thread starter andphy
    Matrix
The discussion revolves around the properties of unitary matrices, specifically whether the transpose conjugate of a unitary matrix is equal to the identity matrix. Participants explore the verification of unitarity through matrix multiplication and the relationships between a matrix and its inverse.
  • One participant asserts that a unitary matrix's transpose conjugate should equal its inverse, seeking confirmation of this statement.
  • Another participant explains that to verify the unitarity of a matrix, one should check if the product of the matrix and its transpose conjugate equals the identity matrix.
  • A participant questions the correctness of a specific matrix multiplication, suggesting that the matrices presented do not yield the expected inverse.
  • Another participant confirms the transpose conjugate of a given matrix and claims it is the correct inverse, expressing confusion over an alternative matrix presented.
  • There is a clarification regarding the product of two matrices, with one participant correcting a previous statement about the identity matrix and confirming the product yields the identity matrix.
  • One participant acknowledges a mistake in terminology, clarifying that they meant to refer to the identity matrix rather than the inverse.
Participants express disagreement regarding the correctness of specific matrix products and their interpretations of unitary properties. The discussion remains unresolved as different views on the matrix relationships are presented.
There are unresolved issues regarding the definitions and calculations of matrix products, as well as the assumptions made about the matrices involved.
andphy
Hi,
A unitary matrix should have it transpose conjugate equal to its inverse. Please confirm that this statement is correct and check attached matrix as they are not equal and in doubt if I did correctly.
Thanks.
Hi,
suppose to have an unitary matrix (##U \in \mathbb{C}^{n \times n}##, so that ##U^{\dagger}=U^{-1}##), if you want to verify the unitariety of your matrix, just check if ##UU^{\dagger}= \mathbb{I}##.
That helps thank you.
Are you saying (in the attached file) that ##\begin{pmatrix}i & 0\\ 0 & 1\end{pmatrix}## is the inverse of ##\begin{pmatrix}1 & 0\\ 0 & i\end{pmatrix}##? It's not. To see this, just multiply these two matrices together.
You have at one point, that the "transpose conjugate" of [itex]\begin{bmatrix}1 & 0 \\ 0 & i\end{bmatrix}[/itex] is [itex]\begin{bmatrix}1 & 0 \\ 0 & -i\end{bmatrix}[/itex]. That is correct and that is the inverse matrix.
Below that, you have "inverse matrix" and [itex]\begin{bmatrix} i & 0 \\ 0 & 1\end{bmatrix}[/itex]. I don't know where that came from!
Right the product will result in the inverse:
1 0
0 1
correct ?
1 0
0 1
correct ?
What product? The product of the two matrices in post #5 is ##\begin{pmatrix}i & 0 \\ 0 & i\end{pmatrix}##. As HallsofIvy said, the inverse of ##\begin{pmatrix}1 & 0\\ 0 & i\end{pmatrix}## is ##\begin{pmatrix}1 & 0\\ 0 & -i\end{pmatrix}##. The product of these two matrices is the identity matrix.
sorry meant to say identity matrix (not inverse) - thank you.
