Is there a closed form of this expression?
  • Context: Graduate
  • Thread starter Thread starter blahdeblah
    Closed Expression Form
6 replies · 3K views
blahdeblah
Hi,
(not homework/academic)
Is a closed form of the following expression possible? Either way, some pointers in the right direction would be really helpful.
[tex] H(s)=\sum_{n=-\infty}^\infty \frac{k^n}{k^n+a/s}[/tex]
Thanks,
D
Mathematics news on Phys.org
Are a, s and k numbers? If so then this sum is divergent - as n goes to +/- infinity, the summand converges to 1 depending on whether k is larger than or smaller than 1
Sorry, the process of posting this, made me think of something which might be helpful:
[tex] H(s)=\sum_{n=-\infty}^\infty \frac{1}{1+a/(s.k^n)}[/tex]
so...
[tex] H(s)=\sum_{n=-\infty}^\infty \frac{1}{1+a.k^{-n}/s}[/tex]
I might be able to google this one as it looks a bit more like a standard form of something.
a is a constant, yes and s is a variable (actually frequency in my application).
I already know from experimentation in Mathcad that an expression using this basic block produces a reasonable result (I suppose I should say bounded). The original expression is 2nd order and the associated response in s tends to 0 as s->0 and as s->INF. I managed to break down the original into a partial fraction sum so could treat it as 2 independent infinite sums of 1st order functions like the one shown. I didn't consider if/whether the 1st order expressions would diverge or not.
Perhaps I should post my original problem.
Here is my original problem:
[tex] FB(s)=\sum_{n=-\infty}^\infty \frac{a(k^ns)}{(k^ns)^2+a(k^ns)+1}[/tex]
This is what I really want to obtain the closed form solution for.
Entirely inadequate. Please restate the question precisely defining what a, k, and s are and not just "numbers" either.
k is a real scalar > 1
a is a real scalar > 0
s is a imaginary scalar > 0
My first post asks if there is a closed form expression of the infinite sum given. If the answer is yes, then some guidance in the right direction to help to obtain it would be very helpful.
If a solution is indeed available then I think it follows that the expression in my last post (#6) can be solved.
