Is there a difference in polarity between maleic acid and fumeric acid?
Maleic acid exhibits greater polarity than fumaric acid due to the additive effect of its two carboxylic acid (-COOH) groups, while in fumaric acid, the polarities of these groups cancel each other out. The reported Rf values of 1.4 for maleic acid and 4.5 for fumaric acid are atypical, as Rf values are generally within the 0 to 1 range. It is crucial to understand that Rf is not a property of a solvent but a characteristic of the solvent/substance/stationary phase combination.
  • Understanding of Thin Layer Chromatography (TLC)
  • Knowledge of polarity in organic compounds
  • Familiarity with carboxylic acid functional groups
  • Basic principles of solvent interactions in chromatography
  • Research Thin Layer Chromatography (TLC) techniques and their applications
  • Study the polarity of organic compounds and how it affects chromatography
  • Learn about the structural differences between maleic and fumaric acids
  • Explore the concept of Rf values and their significance in chromatography
Chemistry students, organic chemists, and laboratory technicians involved in chromatography and compound analysis will benefit from this discussion.
MarcL
I was wondering because I did a TLC experiment where maleic acid has a RF of 1.4 and fumeric acid has an Rf of 4.5. Everywhere says that a longer Rf means that the solvent is less polar than a smaller Rf solvent. However I read somewhere else that Maleic acid has the same polarity as fumeric acid.
thanks for the help guys
Chemistry news on Phys.org
As you were already told elsewhere, Rf is typically reported as belonging to 0..1 range, so the values you have listed look strange.
Rf is not a property of a solvent, it is a value characteristic of a solvent/substance/stationary phase triplet.
Neither maleic nor fumaric (note the spelling) acid are liquid at room temperature, so neither of them was a solvent here.
Hard to answer the question, when there is so much confusing data in your post.
Fumaric acid has lesser polarity than maleic acid as in fumaric acid polarities of the two-COOH groups get canceled so there is polarity only due to the two -H whereas in maleic acid the polarities of the two -COOH groups get added along with polarities of the two -H
  • · Replies 19 ·
9K
