Is There a Limit to Solving Difficult Polynomial Problems?
  • Topic:
  • Thread starter Thread starter Dethrone
    Hard Limit
14 replies · 15K views · last reply
Dethrone
Is there a number "a" such that
limit of ((3x^2 + ax + a + 3) / (x^2 + x -2)) as x approaches -2.
I have attached a picture of this problem for those who need a visual aid and a side for "hints". I have been trying to solve this question with limited success.
You can directly follow the hint
$$\lim_{x \to -2}3x^2+ax+a+3=0$$
I realize that, but I don't understand the hints leading up to that point. Can you explain or elaborate? Like the (3x + k).
Let us look at an easier example
$$\lim_{x \to 2}\frac{x^2-a}{x-2}$$
So , what should be the value of $a$ so that the limit exists and why ?
Hint #1: It is easy to see that the denominator factors as $(x-1)(x+2)$. Since the limit goes to $x=-2$, we must get rid of the $(x+2)$ term in the denominator. To do this, the numerator also has to factor with an $(x+2)$ term.
Hint #2: The leading coefficient of the numerator is 3, and one of its factors ($(x+2)$) has a leading coefficient of 1, so the other factor has a leading coefficient of 3, so it is in the form $(3x+k)$, for some constant k.
Hint #4: Expanding $(x+2)(3x+k)$ gives $3x^2+(6+k)x+2k$, which in turn gives $6+k=a$ and $2k=a+3$. Using this, it is easy to solve for a and k, which will give the factors of the numerator.
- - - Updated - - -
Rido12 said:
(x-2), right?
Actually, I'm pretty sure he meant a constant term, so no. Try to find an $a$ such that the numerator contains an $(x-2)$ term.
- - - Updated - - -Actually, I'm pretty sure he meant a constant term, so no. Try to find an $a$ such that the numerator contains an $(x-2)$ term.
The problem lies on Hint two; I lost you there D:
Then a could be 4?
We want the numerator to factor as $3x^2+ax+a+3=(x+2)(mx+k)$ for some coefficients m and k. Expanding this gives $3x^2+ax+a+3=mx^2+kx+2mx+2k$. Therefore, $m=3$ and restrictions to $a$ can be made.
- - - Updated - - -
Rido12 said:
Then a could be 4?
Yes, it is. The numerator can factor as $$(x+2)(x-2)$$
*Edit* Actually, you don't even need to find restrictions to a. You can solve for it directly using Hint #4.
- - - Updated - - -Yes, it is. The numerator can factor as $$(x+2)(x-2)$$
Thanks, I get it now, but, what led you choose "(mx+k)"? Could you not just have done (x+2)(x+k)?
EDIT: Oh, could "m" be representing any arbitrary number?
Expanding $(x+2)(x+k)$ gives $x^2+(k+2)x+2k$, where the polynomial we want is actually $3x^2+ax+a+3$. Note that the coefficient of $x^2$ in the cases are different. If we want the equality to be satisfied for all x, we want the coefficients to be the same.
- - - Updated - - -
It is a variable which we solved for.
- - - Updated - - -It is a variable which we solved for.
If I wanted it in the form $3x^2+ax+a+3$, and I had to multiple (something)(x+2) to obtain it in that form, it wasn't intuitive for me to multiple that by "(mx+K)". It works out, but I wouldn't have came up with that immediately ... so would I have to use like trial and error to do so, or is there some sort of principle?
What's wrong with $$(mx+k)$$?
Nothing, it's just that I wouldn't have come up with that straight off the bat. If I needed it in the form 3x2+ax+a+3, multiplying (x-2) by "mx+k" wouldn't have been apparent. How were you able to determine so quickly that "mx+k" was the ideal candidate?
The polynomial you were trying to factor was of degree 2, so there are two factors of degree 1, that is, of the form $(ax+b)(cx+d)$.
Thank you!
