Is there a see-through material with low outgassing rate?
The discussion revolves around the search for a transparent material suitable for a low-atmospheric vacuum chamber that minimizes outgassing, specifically targeting pressures below 10^-7 torr. Participants explore various materials and design considerations relevant to the construction and functionality of the vacuum chamber.
  • Experimental/applied
  • One participant inquires about the availability of transparent materials with low outgassing rates for a vacuum chamber project.
  • Another participant suggests that borosilicate or aluminosilicate glass could be potential materials but notes the necessity of using a getter or pump to maintain low pressure, along with concerns about implosion risks.
  • There is a discussion about the feasibility of constructing a clamshell-style chamber and the challenges related to sealing and maintaining low pressures.
  • One participant questions the effectiveness of commercial vacuum viewports, mentioning that some are rated for lower pressures.
  • Another participant proposes the idea of building multiple copies of the apparatus to reduce downtime during testing.
  • Participants express interest in discussing further details about the apparatus and its design considerations.
Participants express varying opinions on the materials and design strategies for the vacuum chamber, with no consensus reached on the best approach or material. The discussion remains unresolved regarding the optimal solution.
Participants mention specific challenges such as bake-out time, resealing, and the potential need for active pumping on the system, which may affect the choice of materials and design.
Individuals involved in vacuum technology, materials science, or experimental physics may find this discussion relevant, particularly those interested in the design and construction of vacuum chambers.
Daniel Sadlier
I am helping one of my old physics professor and his Phd design a low-atmospheric vacuum chamber and we're looking at different materials to prevent outgassing. However the tank is almost 1m long and all the equipment inside must be taken out and checked after each test. It would be nice if we could see into see which components aren't working or that need to be replaced. Is there a material out there that is transparent and has a minimal outgassing rate? The vacuum chamber must reduce to less than 10^-7 torr.
Thanks!
Bake out time, resealing, outgassing? Any chance you can build multiple copies of your apparatus, and switch from "failed" to back-up "n" for lower down-time?
Borosilicate or aluminosilicate glass could work, but would require the use of a getter or pump to maintain that kind of pressure. There is also the risk of implosion, and it would probably be difficult to find someone to build a chamber that large.
W.r.t. constructing the chamber sliced down the middle (per your other thread,) I think you could definitely get away with a clamshell style chamber, although the surface area of the seal would probably be prohibitive for maintaining pressures that low. Can you actively pump on the system?
Are you at liberty to discuss any other details of the apparatus? An ultra-sciencey detector sounds right up my alley ;)
What is wrong with commercial vacuum viewports? Google found some rated for even lower pressures.
10K
11K
