Is there a way to determine if an integral exists for a non-elementary function?
  • Context: Graduate
  • Thread starter Thread starter zeroseven
    Integrating
The discussion revolves around the existence of integrals for non-elementary functions, specifically focusing on whether certain integrals can be expressed in closed form. Participants explore the limitations of computational tools like Mathematica in determining integral existence and the theoretical frameworks that may support or challenge these findings.
  • One participant questions the existence of a closed form for the integral of 1/(x+ln(x)), noting that Mathematica cannot compute it.
  • Another participant suggests that if Mathematica cannot find a solution, it implies that no solution exists in terms of standard integrals, based on the algorithm's reliability.
  • There is uncertainty expressed about how to prove that a solution does not exist for an integral, with some suggesting that this can be done by hand or through algorithms.
  • Participants discuss the Risch algorithm and its role in determining integral existence, with one asserting that Mathematica uses a version of this algorithm.
  • Questions arise about whether the Risch algorithm's applicability extends to non-elementary functions, with a participant citing the need for caution regarding its limitations.
  • Richardson's theorem is mentioned as a counterpoint, indicating that not all combinations of functions can be handled by the Risch algorithm.
Participants express differing views on the implications of Mathematica's inability to compute certain integrals, with some asserting it proves non-existence while others caution against generalizing this conclusion. The discussion remains unresolved regarding the applicability of the Risch algorithm to non-elementary functions.
Participants note that the Risch algorithm's effectiveness may depend on specific conditions and that practical limitations exist in applying theoretical results to computational scenarios.
zeroseven
I've been trying to figure out how to integrate 1/(x+ln(x)) but am not getting anywhere. Mathematica can't do it, and I haven't found it in lists of integrals.
Does anyone know if this integral exists in closed form?
Same goes for (x+ln(x))/(1+x+ln(x))
Thanks!
zeroseven
If mathematica can't do it, then it means there is no solution in terms of standard integrals. This is because the algorithm employed by mathematica is a very good one. If a solution exist, then the algorithm finds it. And if the algorithm fails, then that implies that a solution doesn't exist. So it goes both ways.
Thanks, that's helpful and very interesting.
I have no idea how I would even begin to go about proving that a solution doesn't exist for an integral! Is this something that can only be done by computer algorithms?
No, it can be done by hand too.
See http://en.wikipedia.org/wiki/Liouville's_theorem_(differential_algebra) and http://en.wikipedia.org/wiki/Risch_algorithm
A good book on the topic is Geddes: https://www.amazon.com/dp/0792392590/?tag=pfamazon01-20 (despite its name, it's a math book and not a programming book)
Thanks again, I always wondered how we could be sure that the integral of exp(-x^2) doesn't exist!
So does this mean that when Mathematica works on an integral, it's actually running a rigorous mathematical proof on whether that integral exists or not? Does it use the Risch algorithm that you just linked to?
This leads me to a follow-up question.. if these algorithms work for elementary functions, does it extend to non-elementary functions? For example, if I ask Mathematica to
Integrate[1/(x + ProductLog[x]), x]
and it can't do it, does this prove that an integral doesn't exist in terms of the function ProductLog?
It uses an implementation of the Rish algorithm, yes. So if mathematica can't calculate an integral, then it actually proves that it can't be calculated. Of course, the proof is never shown, because it's not very interesting. But in principle, mathematica could be used to prove that integrals can't be calculated.
But be aware that the practical situation is a bit more complicated. The wiki on Rish algorithm already shows you that there is a certain dependence on initial conditions. Also, the Rish assumes that polynomials can be factored exactly, this might not be true in practice.
I don't know about what the Rish algorithm does with these. But Liousville's theorem seems to be able answer questions like those. I don't know about mathematica's implementation to say with confidence whether it proves the non-existence of this integral. It is however something you can certainly do in theory (by hand).
Thanks again micromass.
That solves my problem (or actually shows that it is unsolvable), and makes me appreciate Mathematica a bit more!
Cheers,
zeroseven
Not in general. For example applying Richardson's theorem we see that "elementary functions + absolute value function" has no equivalent to Risch.
