Is there a way to verify that Bivariate Normal correlation?
  • Context: Graduate
  • Thread starter Thread starter Ashton
    Correlation Normal
The discussion revolves around the challenge of calculating the expected value E(XY) for a bivariate normal distribution. Participants explore methods for evaluating the integral involved in this calculation, including potential transformations and the implications of the bivariate normal density function.
  • One participant expresses difficulty in finding E(XY) and describes the integral ∫xy f(x,y) dy dx, questioning if there are tricks to evaluate it.
  • Another participant suggests that changing to polar coordinates might simplify the integral, although acknowledges the presence of xy in the integrand could allow for evaluation without this transformation.
  • A participant confirms the presence of an e^(-xy) term in the bivariate normal density and questions whether it is still possible to evaluate the integral without transforming to polar coordinates.
  • One participant mentions that the standard trick for evaluating related integrals involves converting to polar coordinates, noting that the Cartesian form is challenging.
  • Another participant indicates that their attempts at the suggested approach were not straightforward and seeks advice on finding E[XY] using the PDF of the bivariate normal distribution.
  • A participant asks for the means and standard deviations of the distribution, suggesting that if both variables are N(0, 1), the formula for E(XY) would be simpler.
Participants do not reach a consensus on the best method to evaluate the integral for E(XY), and multiple approaches are discussed without resolution.
Participants express uncertainty regarding the specific form of the integral they are trying to evaluate, and the discussion includes various assumptions about the parameters of the bivariate normal distribution.
Ashton
My main difficulty is finding E(XY), where if we find it by integrating, we get ∫xy f(x,y) dy dx where f(x,y) is the bivariate normal density function. This integral is a nightmare... are there any tricks to evaluating this integral, or finding E(XY) for that matter?
I think that this would be your integral: ∫ ∫ xy f(x,y) dy dx; that is, an iterated integral. Because of the presence of ##e^{-x^2 - y^2}## (I'm really simplifying here), a standard trick is to change the integral to polar coordinates instead of Cartesian coordinates, although the presence of xy in the integrand might make the integral doable without changing to polar coordinates.
I apologize, that was indeed what I meant by my integral. There is also an e^(-xy) term in the bivariate normal density, do you think it's still possible without transforming the integral to polar coordinates?
And thank you for the reply.
It's hard to say without seeing the integral. The trick I suggested was the standard one for evaluating ##\int_{-\infty}^{\infty} e^{-x^2}dx##. In Cartesian form, this integral can't be done, but by looking at the related iterated integral, and converting to polar form, the integration is straightforward.
I actually tried that approach, but it's not quite clear cut.
I am not sure how to put TeX into these forums, but the PDF of the bivariate normal density can be found in this link: http://mathworld.wolfram.com/BivariateNormalDistribution.html
Do you have any advice on how to find E[XY] with that PDF? That is, double integrating over 2-dimensional reals xy f(x,y).
What are the means and st. deviations of your distribution? If both variables are N(0, 1) the formula is a lot simpler. It would be helpful to actually see the integral you're trying to evaluate.
  • · Replies 21 ·
  • · Replies 27 ·
