Is there action at a distance at the atomic level in physics?
  • Context: Undergrad
  • Thread starter Thread starter sahashmi
The discussion revolves around whether atomic interactions occur through forces that propagate between atoms or if they can be considered as action at a distance. Participants explore this question from both classical and quantum perspectives, examining implications for understanding atomic behavior and interactions.
  • Some participants suggest that classical treatment of atomic interactions involves electromagnetic forces that propagate through space, implying no action at a distance.
  • Others argue that in quantum mechanics, the concept of forces propagating between particles is not applicable, leading to a different understanding of interactions.
  • A participant questions how one might experimentally differentiate between action at a distance and propagating forces in atomic interactions.
  • Some contributions reference Heisenberg's realization that interactions between elementary particles can only be described mathematically, emphasizing the role of the S-Matrix in modern particle physics.
  • There are claims that some participants are resistant to accepting quantum theory, seeking classical explanations instead.
  • One participant mentions Wheeler-Feynman’s theory as a potential avenue for exploration regarding action at a distance, specifically in the context of electromagnetism.
Participants generally disagree on the nature of atomic interactions, with competing views on whether they can be described as action at a distance or through propagating forces. The discussion remains unresolved, with no consensus reached.
Some arguments hinge on the definitions of action at a distance and the applicability of classical versus quantum mechanics, which may not be universally accepted among participants. There are also references to specific mathematical frameworks that may not be fully explained in the discussion.
sahashmi
TL;DR
See title
When atoms interact each other, are they interacting through some form of force that propagates between the atoms, or is this action occurring at a distance?
Newton’s gravity theory famously posited action at a distance: objects affecting each other at a distance with nothing propagating between them in space. Now, we know that gravitational waves propagate between masses.
I’m now curious as to whether interactions in the atomic realm are “at a distance” or always through forces propagating through space
sahashmi said:
TL;DR Summary: See title
You can treat the problem classically, in which case the forces between atoms are electromagnetic, so carried by the electromagnetic field, no action at a distance. Of course this treatment will only work in a few cases; more often we get results that don't match observation, such as the classical prediction that atoms are unstable.
Or you can treat the problem quantum mechanically, in which case the question is meaningless - there's no notion of forces propagating between particles located at points in space. We get results that match our measurement result and that's as good as it gets with QM.
Off topic here, but that second sentence is a non-sequitur, unrelated to the first.
How would you do an experiment to tell the difference?
"Gravitational waves propagate between masses" is not how, for example, the Earth and other planets remain within the Sun's gravitational field in GR. GR does predict gravitational waves, but it does not say that all "gravitational interactions" between masses are due to propagating gravitational waves.
Neither. It was Heisenberg who first realised that interaction between elementary particles could only be described mathematically. These mathematical calculations are what modern particle physics is all about. The main tool in this respect is the so-called S-Matrix, derived from QED/QFT:
https://en.wikipedia.org/wiki/S-matrix
For example, electron-positron interactions are described as Bhabha scattering. This was first calculated by Bhabha in 1935. If you were a graduate particle-physics student this is what you would spend your time learning:
https://en.wikipedia.org/wiki/Bhabha_scattering
This is just a refusal to accept quantum theory. You want a classical explanation, and because there cannot be a local classical one, you look for an "action at a distance" classical explanation.
No, I want an explanation, “classical” or not
  • Skeptical
Nice, provocative question. As a starter, look into Wheeler-Feynman’s theory; perhaps the Wikipedia article on action at a distance. But keep it “low” and confine it to electromagnetism only.
Well, quantum mechanics is an explanation! But you don't accept it. You want a different one, you want a classical one.
What your posts show that you want is to keep harping on the same questions regardless of the answers you get. Enough is enough.
This thread is closed.
  • · Replies 48 ·
  • · Replies 20 ·
  • · Replies 16 ·
  • · Replies 97 ·
11K
  • · Replies 30 ·
