Is there any program I could download to display my CPU temperature?
The discussion revolves around finding software to monitor CPU temperatures on a Windows Vista Home Premium 64-bit system. Participants share their experiences and recommendations for programs that can display CPU temperatures on the desktop, as well as inquire about ideal temperature ranges for a specific CPU model.
  • One participant mentions they can only view CPU temperatures in the BIOS and seeks a program for desktop monitoring.
  • Another participant suggests SpeedFan as a potential solution for monitoring CPU temperatures.
  • A different participant recommends HWMonitor, stating it is the best they've found for this purpose.
  • One participant notes that idle and load temperatures can vary depending on the heatsink, sharing their own experience with a Q9550 CPU, which idles around 30 degrees and reaches 40-50 degrees under load.
  • This participant also points out that there may be discrepancies between core temperatures and system CPU temperatures, explaining the sources of these readings.
  • Another participant shares a link to an article that provides a detailed description of how to check CPU temperature.
Participants generally agree on the usefulness of HWMonitor and SpeedFan for monitoring CPU temperatures, but there is no consensus on the ideal temperature ranges, as individual experiences vary.
Participants mention that temperature readings can differ based on the specific hardware configuration, such as the heatsink used, and that core temperature readings may not always be accurate.
The_Absolute
Right now, I can only view my CPU temperature in the BIOS menu. I can view my GPU temps in the ATI catalyst control center. I cannot view my CPU temperatures in windows vista home premium 64-bit.
Is there any program I could download which would allow me to view my CPU temperatures in desktop? I have a Core 2 Quad Q9400 2.66GHz @2.66GHz, 6GB of DDR2 800MHz RAM, an Intel G33 motherboard, and an ATI Radeon HD 4850 GPU.
What are the ideal idle and load temperatures for my C2Q CPU?
Computer science news on Phys.org
depending on your heatsink, the idle and load temps are going to vary.
I have a Q9550 and it idles around 30deg, with max load around 40-50
I'd also recommend HWMonitor, but you'll probably notice a difference in the stated temperatures from your individual cores and from the system CPU temp. This is because the core temperatures are from onboard the chip (and to be honest, arent the most accurate thermistors; they tend to get stuck), and the system cpu temperature is actually from the motherboard (this is the temperature you'll see in the BIOS)
This article has a detailed description how to check CPU temp
http://digitalblggr.blogspot.com/2010/01/overclocking-dilemma_07.html
www.digitalblggr.blogspot.com
  • · Replies 43 ·
41K
