Is there anything wrong with how the supremum of a set is written?
  • Context: Undergrad
  • Thread starter Thread starter Eclair_de_XII
    Set Supremum
The discussion centers on the correct syntax for expressing the supremum of a set, particularly in relation to continuous functions and compact sets. It is established that while a set A being bounded above does not guarantee that the image f(A) is also bounded above, the combination of a continuous function f and a compact set A ensures the existence of a supremum, and potentially a maximum. The conversation highlights the importance of understanding the properties of compactness and continuity in mathematical analysis.
  • Understanding of supremum and maximum in real analysis
  • Knowledge of continuous functions and their properties
  • Familiarity with compact sets in topology
  • Basic concepts of boundedness in mathematical functions
  • Study the properties of compact sets in topology
  • Learn about continuous functions and their implications on boundedness
  • Explore the relationship between compactness and continuity in mathematical analysis
  • Investigate examples of functions that are not bounded above on non-compact domains
Mathematics students, educators, and researchers interested in real analysis, particularly those focusing on the properties of functions, supremum, and compactness in topology.
Eclair_de_XII
TL;DR
Let ##A\subsetℝ## be bounded from above. Let ##f:A\rightarrow ℝ##. Then can I write the supremum of the image of ##A## through ##f## as ##\sup f(A)##, or do I have to write it as ##\sup\{f(x):x\in A\}##?
I'm just having random thoughts today, and I didn't know where to put this, since this isn't even a homework problem.
Anyway, is my way of writing the supremum of a set correct syntax-wise, or no?
Both are the same thing: simply because ##f(A) = \{f(a)\mid a \in A\}## by definition. That A is bounded above does not imply that f(A) is bounded above, so the supremum may not exist as a real number.
I think having a continuous ##f## and compact ##A## would guarantee the existence of a supremum (probably even maximum).
Yes, that's work. You are right that it is even a maximum because the image of a compact set under a continuous map is compact, so the image is in particular closed and bounded hence contains its supremum.
What we need here is the requirement that f is bounded above, but this is just a reformulation of f(A) is bounded above.
Oh, I should have caught that. My mista;e; thanks for the reply, besides.
A situation where that happens is the function (defined on a half-open interval)
##f:]0,1]\mapsto \mathbb{R}## such that ##f(x)=1/x##
which gets arbitrarily large values when approaching ##x=0##.
If the domain is compact (closed and bounded), this can't happen because in conventional calculus you can't have a function that is defined as "infinite" at an endpoint of the domain.
  • · Replies 61 ·
  • · Replies 18 ·
  • · Replies 18 ·
