Is there such a thing as an inverted zener diode?
  • Thread starter Thread starter warfreak131
    Diode
The discussion centers on the concept of a diode that allows current to flow only when the voltage is below a certain threshold. Participants clarify that while Zener diodes permit reverse current flow above a specific voltage, no single semiconductor device exists that operates in the opposite manner. Suggestions include using a fuse or Raychem's Polyswitch for overcurrent protection, but these devices are not voltage-dependent. A linear voltage regulator is mentioned as a viable solution for maintaining output voltage below a set maximum, but it requires a circuit design rather than a standalone diode.
  • Understanding of Zener diodes and their operation
  • Knowledge of circuit protection devices like fuses and Polyswitches
  • Familiarity with linear voltage regulators and their functionality
  • Basic circuit design principles for over-voltage cutout
  • Research the design and application of linear voltage regulators
  • Explore the functionality and use cases of Raychem's Polyswitch
  • Investigate circuit designs for over-voltage protection
  • Learn about the characteristics and limitations of fuses in electrical circuits
Electrical engineers, circuit designers, and anyone interested in voltage regulation and over-current protection solutions.
warfreak131
Zener diodes act like regular diodes, except that they allow current to flow in the reverse direction if the voltage is high enough. That is, current with voltage ABOVE a certain value will flow.
My question is, is there such a diode that only allows current to flow if the voltage is BELOW a certain level?
A fuse? (well, fuses are based on current and not voltage...)
Or maybe Raychem's Polyswitch? (same caveat, though...)
http://www.te.com/en/products/circu...nt-devices/polyswitch-resettable-devices.html
Think about what you are saying. Anything that allows current to easily flow will not likely allow a voltage to build up across it. So Berkemans suggestion of a fuse is pretty close to accurate. You could consider a wirewound resistor also. When they are over heated (too much current) they open up instead of sit and smoke.
A linear voltage regulator will hold output to a set maximum voltage, and if the input falls below Vreg, power will continue to flow.
A basic 3-terminal regulator can be used without any additional components, so it's really no harder to use than a Zener diode.
No, not a single semiconductor device. But you can build a circuit to do this, it has over-voltage cutout.
  • · Replies 42 ·
  • · Replies 32 ·
  • · Replies 24 ·
