Is this a reasonable approach to calculating pressure difference?
6 replies · 4K views · last reply
ana111790
What is the pressure difference between points A and B (point where glycerol and air heads meet) in the picture, if d1 = 0.50 meters, d2 = 0.25 meters, and d3 = 0.71 meters and d4 = 0.86 meters. (ρH2O= 1.00 x 10^3 kg/m^3, ρgly = 1.25 x 10^3/m^3)
[PLAIN]http://img535.imageshack.us/img535/5260/pressureproblem.jpg
I know that pressure difference can be found through
P2-P1=ρ2gh2 - ρ1gh1
I am confused because there are 3 different substances involved, glycerol, air and water.
What I did was I took the pressure at the bottom of the system to be the h0=0 (reference height) and calculated Pressure at A and Pressure at B independently and then subtracted them.
So:
Pressure at point A = ρH2O*g*d1 + ρglycerol*g*d2
Pressure at point A = (1000kg/m^3 * 9.8 m/s^2 * .5m) + (1250kg/m^3 * 9.8m/s * .25m)
Pressure at point A = 7960 Pa
Pressure at point B = ρglycerol*g*d2 + ρglycerol*g*d3 + ρglycerol*g*d4sin45
Pressure at point B = (1250kg/m^3 * 9.8m/s^2 * .25m) + (1250kg/m^3 * 9.8m/s * .71m) + (1250kg/m^3 * 9.8m/s^2 *.86m*sin45)
Pressure at point B = 19200 Pa
Pressure difference = Pressure at point B - Pressure at point A
Pressure difference = 11200 Pa
Does this seem like a reasonable approach and answer?
Thanks!
please clarify which are the points A and B.
I took point A to be where distance d1 starts, along the the H2O head as nothing is mentioned in the problem statement about it.
Point B is explained in the problem as "point where glycerol and air heads meet".
Thank you.
If you consider point A to be where distance d1 starts, then your calculation of pressure at A is incorrect. It would not depend on glycerine column d2, it would just be equal to the pressure of H2O inside the container, which is unknown.
Also, the pressure at B would be equal to pressure of air in container, and not what you calculated, which is also unknown.
I think the questions is not clear. It would most probably be right to consider point A as the point where d2 ends at the bottom, that is, the lower point of (d1 + d2). In that case we can calculate pressure difference.
hmm. In the picture there is a lower case "a" where the H2O head meets the tube with H2O, and a lower case b where the air head meets the tube with air. Not sure if that is relevant.
I calculated those values relative to an arbitrary h0 which I chose to be at the very bottom of the system, so point A is higher than my h0 but point B is even higher.
This question is very confusing.
