Is this correct converting (I am confuse)
  • Thread starter Thread starter BunDa4Th
The discussion centers on converting a temperature difference of 460°C to Fahrenheit and Kelvin. The initial calculations yielded incorrect results, with one user suggesting that the temperature difference should be treated differently than absolute temperatures. It was clarified that for temperature differences, the conversion to Kelvin does not require adding 273.15, as the intervals are equivalent. The correct conversion for the temperature difference to Fahrenheit was emphasized, indicating that only the factor difference should be considered. Ultimately, the consensus is that the temperature difference remains consistent across scales, simplifying the conversion process.
BunDa4Th
The temperature difference between the inside and the outside of an automobile engine is 460 C°.
a) Express this temperature difference on the Fahrenheit scale.
b) Express this temperature difference on the Kelvin scale.
T_F = 9/5T_c + 32
T_K = T_c + 273.15
a) i got 860
b) i got 733.15
why is it marking this incorrect what am i doing wrong?
do you have the right amount of significant figures? maybe it asks for 4 or just 3
im pretty sure I am using the right significant figure since from C to F it gave 860 exact and to convert C to K its basically adding 273.15 i believe. it say my answer is 10%-100% differ to the correct answer.
460 degrees celcius seems a bit high. Are you sure it's not 46.0 degrees celcius?
Yea, I am pretty sure its 460 degrees celcius since i did a direct copy and paste.
Hey soo the answer would be 450 k and 810 F
Tf = 9/5*450 C
=810 F
Kelvin = Celcius hence 450C =450K temp differences are the same change is constant
Since you're expressing a difference in temperature, madhiab would be right in saying that only the the factor difference should be important. So the change in temperature in Kalvin would be exactly the same as the temperature difference in degrees Celsius. However, use the same factor you used above without changing the initial value (notice it only asks for a change) to convert to fahrenheit.
the question is DIFFERENCE in temp. therefore the +273.15 is not needed, as that would be the Teperature of an object at 460C. Fahrenheit i have no idea as i use metric. also since kelvin interval = celcius interval therefore no need to convert (for diff in temperature).
