Is this integral correct? (expanding the Bessel function into power series )
  • Thread starter Thread starter Rfael
Rfael
integral equality: is this integral correct ?
$$ exp(-x)= \int_{0}^{\infty}J_0 (\sqrt{xt})exp(-t) $$
i have expanded the bessel function into power series and integration term by term
Rfael said:
Homework Statement: integral equality: is this integral correct ?
Almost! According to Mathematica your result is missing a factor of 4:
thanks how about if i put ##J_0 ( 2\sqrt{xt})## instead my original bessel function ?
Yes, that removes the factor of 4 from the answer, as is evident by making a change-of-variables in the first integral above:
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
