Is this the right way to approach solubility problem?
2 replies · 2K views
Sunwoo Bae
7. Lead(II)-carbonate deposits on surface of the water pipes. Taking into account the solubility of lead(II) carbonate calculate the mass of lead dissolved in 1 L of water pipes.
Ksp of PbCO3 = 1.8166 * 10^-7M
Is my work and the answer correct?
If not, how should I approach this problem?
Thank you!
Approach looks OK, no idea if the numbers are correct. Please note PF is not a place for checking your homework.
This is a poorly thought question in general. Solubility of carbonates strongly depends on the pH. Tap water has pH around 7, so carbonates are present mostly as HCO3- and the PbCO3 solubility would be orders of magnitude higher than the one you calculated.
