Jackson Electrodynamics problem 9.8a
The discussion centers on solving Jackson's Electrodynamics problem 9.8a, which involves demonstrating that a classical oscillating electric dipole radiates electromagnetic angular momentum to infinity at a specific rate. Participants clarify that the angular momentum density is derived from the electromagnetic fields and must be integrated over a spherical shell to find the total angular momentum radiated. The correct approach involves using the time-averaged Poynting vector to account for the average flow of angular momentum. There is a focus on ensuring the integration limits and dimensions are appropriate for the problem. Ultimately, the understanding of how to derive the angular momentum radiated to infinity is confirmed through collaborative insights.
andrew1982
9.8a) Show that a classical oscillating eletric dipole p with fields given by (9.18) radiates electromagnetic angular momentum to infinity at the rate
<br /> \frac{d\mathbf{L}}{dt}=\frac{k^3}{12\pi\epsilon_0}\textrm{Im}[\mathbf{p^*\times p}]<br />
Hint: The electromagnetic angular momentum density comes from more than the transverse (radiation zone) components of the field.
Dipole fields (9.18):
<br /> \mathbf{H}=\frac{ck^2}{4\pi}(\mathbf{n\times p}) \frac{e^{ikr}}{r}(1-\frac{1}{ikr})<br />
<br /> \mathbf{E}=\frac{1}{4\pi \epsilon_0}(k^2\mathbf{(n\times p)\times n} \frac{e^{ikr}}{r}+(3\mathbf{n(n\cdot p)-p})(\frac{1}{r^3}-\frac{ik}{r^2})e^{ikr})<br />
(n is the unit vector in direction x)
Electromagnetic momentum density (6.118)
<br /> \mathbf{g}=\frac{1}{c^2}(\mathbf{E\times H})<br />
So I guess the angular momentum density is
<br /> \mathbf{x\times g}<br />
which with the fields in (9.18) simplifies to
<br /> \frac{ik^2}{8\pi^2 \epsilon_0}\mathbf{(n\cdot p)(n \times p^*)}(\frac{k}{r^2}+\frac{1}{ikr^4})<br />
if I use the complex Poynting vector
<br /> \mathbf{E\times H^*}.<br />
From here I'm not sure how to continue. This is the angular momentum density (per volume). If I integrate it over the whole space I get the total angular momentum, not only the part radiated to infinity. Since it is per volume I will not get the right dimension if I do as for the power radiated to infinity (integrate the Poynting vector over a spherical surface, radius R, and let R->infinity). What integration should I do?
I tried to integrate only the part prop. 1/r^2 (since I guess the other part will not "reach infinity") over a sphere with radius R and got
<br /> \mathbf{L}=\frac{ik^3}{6 c \pi \epsilon_0}(\mathbf{p^*\times p})R<br />
This looks similar to the answer, but will diverge in the limit R->inf. I also don't see how to take the time derivative of this. If I use the complex Poynting vector (which I guess I should?) the complex exponentials containing the (harmonic) time dependence will cancel.
Any hint would be appreciated!
Hi
thanks a lot for the link! Very useful website :)
Ok, so my understanding after reading this solution is that the electromagnetic angular momentum that is radiated to infinity in time dt is contained in a spherical shell with radius r->inf. and thickness dr=c dt. So dL/dt is obtained by integrating the angular momentum density over this shell volume and "dividing" by dt.
Furthermore, I should use the time-averaged Poynting vector 1/2 ExH*, since the answer in fact is the average flow of angular momentum to infinity.
Is this understanding correct? Thanks again.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
