Jet + ion lifting hovering jet will it work?
The discussion centers on the feasibility of using an alternator connected to a turbojet to power an ion lifter for hovering capabilities. While ion propulsion has been successfully used in space missions like Deep Space One, it produces minimal thrust, insufficient for a vertical takeoff and landing (VTOL) aircraft. The idea of using ion technology, similar to that employed in ion loudspeakers, raises questions about its practicality for lifting heavier objects. Current ion lifters lack the power needed to lift a jet engine, making them impractical for such applications. Overall, leveraging existing jet engine thrust would be a more effective approach for achieving self-levitation.
phoenixman76
ok, I am not a physics student, engineer, or mathematician, but i have an idea i need to know will work or not. we've all undoubtedly seen star wars ep 1 with the podracer race...floating engines. would an alternator connected to a turbojet produce enough voltage to power an ion lifter? are there any ion lifters powerful enough to lift a jet engine?
Do you know anything about ION loudspeakers?
Link:
http://www.ee.vill.edu/ion/p12.html
The ion speaker takes advantage of the corona discharge effect to produce sound.
If you can move air to generate sound, then why not lift?
You could be on to something.
Deep Space One used ion propulsion. It used solar panels to generate about enough thrust to lift a piece of paper. It take a lot of power to generate thrust that way. Too much for it to be viable for a VTOL aircraft.
Here's the biggest we currently have: http://www.nasa.gov/vision/universe/features/nep_prometheus.html
Besides, if you've already got a jet engine, you could divert the thrust from that to be self-levitating, and you'd get a lot more power from them!
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
