Can Multiplicative Cosets Form a Group for a Subring in a Ring Homomorphism?
  • Context: Undergrad
  • Thread starter Thread starter Mr Davis 97
    Kernel Ring
The discussion centers on the properties of the kernel of a ring homomorphism and the concept of multiplicative cosets in relation to subrings. It is established that the kernel consists of elements mapping to the additive identity (0) rather than the multiplicative identity (1), as not all rings possess a multiplicative identity. The participants explore the implications of defining a set of elements that map to 1 and question whether multiplicative cosets of a subring can form a group. It is concluded that such cosets may not satisfy the necessary group properties without imposing significant restrictions.
  • Understanding of ring homomorphisms and their kernels
  • Familiarity with commutative rings and ideals
  • Knowledge of multiplicative groups and their properties
  • Basic concepts of subrings and cosets
  • Investigate the properties of kernels in ring homomorphisms, specifically in commutative rings
  • Explore the structure of ideals and their role in forming quotient rings
  • Study the conditions under which multiplicative cosets can form groups
  • Examine examples of subrings and their multiplicative cosets in various ring structures
Mathematicians, algebraists, and students studying abstract algebra, particularly those interested in ring theory and group theory.
Mr Davis 97
We know that kernel of a homomorphism consists of all the elements that map to the additive identity, 0. Here is my naive question: Why don't we define the kernel as all of the elements that map to the multiplicative identity, 1? Why isn't there a name for the set of all elements that map to the multiplicative identity?
Because there is none!
The kernel of a homomorphism is what is mapped to the neutral element, whatever this is. In multiplicative groups such as automorphism groups, it is ##1##, and in rings it is ##0##. Not all rings have a ##1## and most of all: most elements do not multiply to ##1##. You can investigate this on your own. Take a ring homomorphism (for the sake of simplicity a commutative ring with ##1## and an endomorphism) ##\varphi\, : \,R \longrightarrow R## and see which properties ##N:=\{\,r\in R\,|\,\varphi(r)=1\,\}## has. Is it an ideal, so that we can factor ##R/N## what we usually want to do with a kernel? Is it at least a subring? What happens if we multiply it with ideals, etc.?
It seems that ##N## is not even a subring, since it is not closed under addition.
A related question I have is it possible to form a ring structure out of the multiplicative cosets of a subring?
Can you explain what you mean by multiplicative cosets? Let's say we have a subring ##S \subseteq R##. Then we can build ##R/S## as a set. If we want to define ##(p+S)\cdot (q+S) = pq + pS +Sq +S = pq+S## we need, ##pS\, , \,Sq \subseteq S##, that is ##S## should be an ideal. In this case ##R/S## is a ring. Now what did you want to do?
Suppose that ##S## is a subring of ##R##. Then if ##r\in R## we can look at the set ##rS = \{rs\mid s\in S\}##. can these multiplicative cosets form a group?
What should be the inverse to ##0\cdot S\,##? I guess you will have to enforce so many restrictions, that you will end up with multiplicative groups.
  • · Replies 41 ·
