Kinematic question, i think it's hard
  • Thread starter Thread starter 9giddjl
    Hard Kinematic
The discussion revolves around a kinematic problem involving two camels departing from the Sphinx at different times and accelerations. Camel A accelerates at 1.30 m/s² for 1.92 seconds, while Camel B accelerates at 1.45 m/s² for 2.84 seconds, starting 52.5 seconds later. To solve the problem, the equations of motion for both camels must be applied, taking into account the time difference. The key equations are v = at for velocity and x = (1/2)at² for distance, with adjustments for the delayed start of Camel B.
  • Understanding of kinematic equations for uniformly accelerated motion
  • Familiarity with concepts of initial velocity and displacement
  • Ability to manipulate algebraic expressions and solve equations
  • Knowledge of time intervals and their impact on motion
  • Study the derivation and application of kinematic equations in physics
  • Learn how to solve problems involving multiple objects with different starting times
  • Explore the use of graphical methods to visualize motion and acceleration
  • Practice similar kinematic problems to reinforce understanding of concepts
Students studying physics, particularly those focusing on kinematics, as well as educators looking for examples of motion problems involving multiple objects and time delays.
9giddjl
kinematic question, i think it's hard:(
Two camels leave the spinx at time 52.5 s apart. The first moves off with a uniform acceleration of 1.30 m/s2, which it maintains for 1.92 s. It then continues with the acquired speed. The second camel moves of with a uniform acceleration of 1.45 m/s2, which it maintains for 2.84 s. It then contiues with the acquired speed. Claculate:
a) the distance they have both traveled when the second camel overtakes the first camel, which has walked in a straight line
b) the time taken by the second camel to catch the first.
a= v-u/t?? not sure..
s=ut+0.5at2
I really don't know how to put the 'two camels leave spinx at 52.5 seconds apart, i don't understand the 52.5 s apart and where to put that into equation. I'm pretty styumped with this question, could someone pls help? I have acceleration for both camels and the time but that's all i have. does u=0? Could i then use the equation s=ut+0.5at2 for each camel to find out their distances and then add them together. I just don't get the 52.5 seconds apart:(
and with question b) i know that the second camel has a greater acceleration than the first but other than that, i don't get it:(
Camel A leaves at time t=0
Camel B leaves at time t=52.5
Camel A acceleration = 1.30
thus
Camel A speed for 1.92 seconds=1.30t
Camel B acceleration = 1.45
Camel B speed for 2.84 seconds=1.45t
Now, position is \frac{1}{2}(v(t))^2, which is derived by integration.
So
Position of the camel A at t=1.92 = \frac{1}{2}((1.92)(1.30))^2
Velocity of camel A at t = 1.92 = (1.92)(1.30)
And
Position of camel B at t = 55.34 = \frac{1}{2}((2.84)(1.45))^2
Velocity of camel B at t = 55.34 = (2.84)(1.45)
And then you solve the problem. Which should be pretty easy.
For uniform acceleration:
v = at + vi, in which vi is initial velocity (which is 0m/s)
x = (1/2)*a*t^2 + vi*t + xi, in which vi is initial velocity (0m/s) and xi is initial displacement (which is 0m).
Since the second camel left 52.5s after the first camel, it starts 52.5s behind the first camel, meaning the time for the second camel is (t - 52.5)
So, the 2 equations you need for the first camel are:
v = at
x = (1/2)*a*t^2
and the 2 you need for the second camel are:
v = a(t - 52.5)
x = (1/2)*a*(t - 52.5)^2
Why don't you guys use LATEX?
-_-
So here you have two ways of looking at the problem =D
52.5 seconds apart means if one camel started of at t=0s the other camle started off att=52.5 s there's a diff of this much time in between them which wud obviously result in diff in distance covered..just calculate the distance travveled by both of them...at the pt where the distance traveled by 2nd camel just becomes equal to that traveled by 1st camel.is the pt where the 2nd one overtakes..use equations of motion in a straight line
  • · Replies 30 ·
