Kinematics with multiple objects
Mike's scenario involves a balloon dropped from a 580 m tower and a potato fired from a cannon at 95 m/s. The equations of motion for both the balloon and the potato were established, with the potato's motion incorporating a negative acceleration due to gravity. The time of collision was calculated to be approximately 9.684 seconds. A clarification was raised regarding the initial positions of the balloon and potato, suggesting that distances should be measured from a common reference point. Accurate measurements are crucial for solving kinematic problems involving multiple objects.
Vontox7
Mike is standing below a tower. His friend on top of the tower which is 580 m drops a balloon at him. At the instant mike fires a potato from a cannon moving at an initial velocity of 95 m/s. How long does it take for the balloon and potato to collide?
vf=vi+at
vf^2=vi^2+2ax
x=vi*t+0.5at^2
x=0.5(vi+vf)t
What i did is split it into 2 parts one for the balloon and potato. The potato equation was
x=95t+0.5(-9.81)t^2
And the balloon equation as
x=0.5(9.81)t^2
and then i set them equal to each other and solved.
I got t=9.684 s
At t = 0 both the potato and balloon are at x = 0 do they both start at the same point? I think you want to measure distances from some common point, either at the bottom of the tower or at the top?
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
