Kinetic Energy and Parabolic Motion
The kinetic energy (K.E) of a shell with a mass of 50 kg, fired at an angle of 60 degrees with an initial speed of 200 m/s, is calculated at its highest point. At this apex, the vertical velocity is zero, but the horizontal component remains. The horizontal velocity is determined using the formula 200cos(60), resulting in 100 m/s. Consequently, the kinetic energy at the highest point is calculated as K.E = 0.5 * (50 kg) * (100 m/s)^2, yielding a value of 2.5 x 10^5 J.
  • Understanding of kinetic energy formula: K.E = 0.5(m)(v)^2
  • Knowledge of projectile motion and its components
  • Ability to calculate trigonometric functions (sine and cosine)
  • Familiarity with the concept of velocity components in physics
  • Study the effects of air resistance on projectile motion
  • Learn about energy conservation in projectile motion
  • Explore advanced projectile motion equations and their applications
  • Investigate the impact of different launch angles on kinetic energy
Students studying physics, particularly those focusing on mechanics and projectile motion, as well as educators seeking to explain kinetic energy concepts in a practical context.
thoradicus
A shell of mass 50kg is fired at 60 degress to the horizontal with a speed of 200 m/s. Neglecting air resistance,calculate the kinetic energy of the shell at the highest point.
K.E=.5(m)(v)^2
usin(θ)
ucos(θ)
My question is shouldn't the K.E of the shell is 0? Since the vertical velocity is zero at the highest point. Should I use horizontal velocty instead? why is that so?
If i use horizontal velocity: 200cos60=100
K.E=(1/2)(50)(100)^2=2.5*10^5
You need the total velocity to calculate the KE. But since the vertical component is zero at the highest point, all you need is the horizontal component.
Exactly. (Don't forget units.)
K.E=.5(m)(v)^2
usin(θ)
ucos(θ)
KE is the energy of motion. The shell is still moving when it's at its zenith (it's moving horizontally).
You could calculate the KE in terms of components, vertical and horizontal, then add them like you add vector components to find the magnitude. But since you know that the vertical component is zero when the shell is at its maximum height, the calculation simplifies to being just the KE due to the horizontal component.
yes u have to use the horizontal component of velocity in this case.
remember the velocity is zero at the topmost point only when the projectile is fired vertically, i.e, with zero horizontal component of velocity. if it is fired with some angle other than 90 deg with the horizontal it has a non zero velocity at the top. that velocity = the initial horizontal component of the velocity. this remains unchanged through out the flight as the gravitational force is a vertical (downward) one and as such can not affect the horizontal component of velocity.
  • · Replies 21 ·
  • · Replies 22 ·
  • · Replies 19 ·
