Kinetic Energy of a Cylinder Rolling Without Slipping
The discussion revolves around the kinetic energy of a cylinder rolling without slipping down an incline. Participants explore how the total kinetic energy can be represented as the sum of translational and rotational kinetic energies, questioning the validity of this representation given the varying speeds of different points on the cylinder.
  • Participants express confusion about how the equation for total kinetic energy accounts for the kinetic energy of individual particles within the cylinder. They question whether the addition of translational and rotational kinetic energies is sufficient, considering that different parts of the cylinder have different speeds. Some suggest visualizing the cylinder as an array of bars to understand the combined motion better.
The discussion is ongoing, with participants sharing various perspectives and attempting to clarify the relationship between translational and rotational kinetic energy. Some have suggested that a calculation might be necessary to justify the equation, while others are exploring intuitive and algebraic arguments. There is no explicit consensus, but several resources and tutorials have been shared to aid understanding.
Participants note that this question is not a formal homework problem but rather a conceptual inquiry into rolling motion. There are mentions of the need for calculus to fully understand the justification for the kinetic energy equation, and some express uncertainty about the implications of the axis of rotation in relation to translational motion.
uSee2
This question is not a homework problem, just something I was wondering about when doing rolling without slipping problems. How can the kinetic energy of something rolling down an incline be represented as the simple addition of the translational and rotational kinetic energies? (Better explanation of my question below)
##KE_{total} = KE_{translational} + KE_{rotational}##
##KE_{total} = \frac {1} {2} mv_{cm}^2 + \frac1 2 I \omega^2##
Given that there is a cylinder rolling without slipping down an incline, the method I was taught to represent the KE of the cylinder was:
##KE_{total} = \frac {1} {2} mv_{cm}^2 + \frac1 2 I \omega^2## Where "cm" is the center of mass, and "I" was about the cylinder's center of mass
I am confused about how the equation above can represent the kinetic energy of the cylinder. The kinetic energy of the cylinder is the kinetic energy of each of its individual particles added together, so I can't really see how that equation above accounts for all that.
I was told that rolling without slipping combines translational and rotational motion, hence why the translational and rotational kinetic energy equations are added together. But, isn't that neglecting that different parts of the cylinder have different speeds? The very bottom of the cylinder at the point of contact has a tangential velocity of 0 while at the very top of the cylinder, it has a much larger velocity. How does the equation account for the kinetic energies of all the particle's KE?
Perhaps you could visualize that cylinder as an array of bars all meeting at their individual middle point.
Each of those imaginary bars would rotate while simultaneously its center of mass translates along a straight line.
In order to start or stop that combined movement, you need energy for the rotation part and for the translation part.
uSee2 said:
Homework Statement: This question is not a homework problem, just something I was wondering about when doing rolling without slipping problems. How can the kinetic energy of something rolling down an incline be represented as the simple addition of the translational and rotational kinetic energies? (Better explanation of my question below)
Relevant Equations: ##KE_{total} = KE_{translational} + KE_{rotational}##
You need a calculation to show that the addition of translational and rotational KE equates to the total. I'm not sure there is a clever argument to justify it without calculation.
I'm sure that calculation must be online somewhere.
Note that it's generally true for any rigid body motion.
Thank you for answering! I do see that in the case of an object spinning while moving through space, that would be true since the tangential velocity at a distance R away from the center of mass would be constant at any point. But when an object is rolling without slipping, the bottom is at rest while the top is moving faster. So any point at an equal distance of R would have varying speeds.
Is the equation just something that works for rigid body motion? I can't exactly find the explanation online somewhere, but do you think that the explanation would involve calculus? If it does, I'm fine with just accepting that the equation "just works" since I still have no knowledge of calculus yet.
The result should be the same by both methods.
The velocity of the top particle is double the velocity of the center or axis of the cylinder, so the circular movement of that particle respect to the contact point (v=0) is harder to stop.
The next bar is in contact with the surface, but our bar is lifting the bottom end via rotation; therefore, its potential energy remains constant (while the cylinder is rolling on horizontal surface).
For an intuitive argument, consider a cart moving at constant velocity v. Inside the cart is a flywheel on a horizontal axis normal to the cart's motion.
To a person in the cart, it takes a certain amount of energy to get the wheel spinning at some rate. To a bystander, would you expect it to take the same amount of energy?
For an algebraic argument, consider an assemblage ##(m_i)## of particles with mass centre at ##\vec r##: ##\Sigma m_i\vec r_i=\vec r\Sigma m_i=\vec r\cdot m##, so ##\Sigma m_i\vec{ \dot r_i}=\vec {\dot r}\cdot m##.
##KE=\frac 12\Sigma m_i\vec{ \dot r_i}^2=\frac 12\Sigma m_i((\vec{ \dot r_i}-\vec {\dot r})^2+2\vec{ \dot r_i}\cdot\vec {\dot r}-\vec {\dot r}^2)##
##=\frac 12\Sigma m_i(\vec{ \dot r_i}-\vec {\dot r})^2+\frac 12\Sigma m_i
2\vec{ \dot r_i}\cdot\vec {\dot r}-\frac 12\Sigma m_i\vec {\dot r}^2##
##=\frac 12\Sigma m_i(\vec{ \dot r_i}-\vec {\dot r})^2+(m
\vec{ \dot r})\cdot\vec {\dot r}-\frac 12 m\vec {\dot r}^2
##=\frac 12\Sigma m_i(\vec{ \dot r_i}-\vec {\dot r})^2+\frac 12 m\vec {\dot r}^2
Lnewqban said:
After reading it, wouldn't that mean that the equation definitely wouldn't work? Since if the axis of rotation was indeed the point of contact, that would mean that there is no translational motion at all. So it would just be:
##KE_{total} = \frac {1} {2} I \omega^2## where ##I## is the moment of inertia about the ground/point of contact.
That is true only instantaneously.
Otherwise, we will have a cylinder constantly rotating about the contact point, and its center the mass will describe a circle of radius similar to the radius of the cylinder.
I do see that it is rotating, but since the axis of rotation is changing every moment it is as if it were moving translationally. But if it has only rotational kinetic energy instantaneously for every instant, wouldn't that mean that it only has rotational kinetic energy for the entirety of its roll?
You can pick an axis and factor the motion of a rigid object into translation of that axis plus rotation about that axis in many ways. There is no one "fact of the matter" on where the energy "really" is or what the axis of rotation "really" is.
But yes, you can do an energy accounting considering that the entirety of the kinetic energy of a rolling tire is always manifested in rotation about the momentary position of the contact patch if you like.
There is no rotation about the center of mass of the cylinder only.
Even in the case of the last post, the CM, as well as other points, are describing a circle.
The rotational inertia to overcome in that case should still be greater than the rotational inertia of the cylinder about its axle.
Please, see:
http://hyperphysics.phy-astr.gsu.edu/hbase/parax.html#pax
Pure translation (skidding cylinder on frictionless horizontal surface) requires certain amount of translational kinetic energy.
Translational work = FS = maS
Pure translation (cylinder rotating around frictionless static axle) requires certain amount of rotational kinetic energy.
Rotational work = τθ = Iαθ
A combined movement requires both, which should be added up.
Please, see:
I'm still confused about the idea that there is no rotation about the center of mass. If there was no rotation about the center of mass, wouldn't there be no translational kinetic energy? But it wouldn't move in a circle like in post #11 since the axis of rotation is constantly shifting.
For the first part, it would take the same amount of energy, right? But isn't this different since all parts of the wheel at the edge are moving at the same tangential velocity, while when the cylinder is rolling without slipping the point of contact has a velocity of 0 while the top has twice the velocity of the center of mass?
Suppose you subdivided the mass ##M## of the cylinder into elemental masses such ##M=\sum_i~dm_i##. Let point ##P## be the point of contact with the surface. This point is instantaneously at rest because there is no slipping.
Let
##\vec R=## the position of the center of mass ##O## of the cylinder relative to ##P##
##\vec r_i=## the position of mass element ##dm_i## relative to ##P##.
##\vec r'_i=## the position of mass element ##dm_i## relative to the center of mass at ##O##.
##\vec v_i=## the speed of mass element ##dm_i## relative to ##P##.
An element ##dm_i## moves with velocity ##\vec \omega\times \vec r'## relative to the center of mass ##O## which moves with velocity ##\vec V_{cm}## relative to point ##P##. Thus the velocity of the element relative to point ##P## is $$\vec v_i=\vec V_{cm}+\vec {\omega}\times \vec r_i'$$ and $$v_i^2=(\vec V_{cm}+\vec {\omega}\times \vec r'_i)\cdot(\vec V_{cm}+\vec {\omega}\times \vec r'_i)=V_{cm}^2+2\vec V_{cm}\cdot(\vec {\omega}\times \vec r'_i)+\omega^2{r'_i}^2.$$The total kinetic energy of the cylinder is $$K=\frac{1}{2}\sum_i dm_i~v_i^2=\frac{1}{2}V_{cm}^2\sum_idm_i+\sum_i dm_i\vec V_{cm}\cdot(\vec {\omega}\times \vec r'_i)+\frac{1}{2}\omega^2\sum_i dm_i{r'_i}^2$$ In the first term $$\sum_i dm_i=M\implies \frac{1}{2}V_{cm}^2\sum_idm_i=\frac{1}{2}MV_{cm}^2.$$In the second term $$\sum_i dm_i\vec V_{cm}\cdot(\vec {\omega}\times \vec {r}'_i)=\sum_i dm_i ~\vec{r}'_i\cdot(\vec V_{cm}\times\vec{\omega})=(\vec V_{cm}\times\vec{\omega})\cdot\sum_i \vec {r}'_i dm_i=0$$because by definition of the center of mass coordinates, ##\sum_i \vec {r}'_i dm_i=0.##
In the third term the definition of the moment of inertia about the center of mass is ##I_{cm}=\sum_i dm_i {r'_i}^2##.
Thus, by adding all the contributions of all elements ##dm_i## to the kinetic energy, we get $$K=\frac{1}{2}MV_{cm}^2+\frac{1}{2}I_{cm}\omega^2.$$
  • Love
The rolling wheel is just the special case when the bottom-most part of the wheel is moving backwards relative to the centre with the same speed as the centre of the wheel is moving forward: ##v_{bot}=v_{centre}+v_{bot-centre}=v_{centre}-r\omega=0##.
Let
This is perfect! Thank you so much, this clears up a lot and makes a lot of sense. Also, was this derivation in a textbook? I feel that my textbooks should've mentioned this derivation as this seems very critical to understanding, I might have missed something
Also off-topic, but do you have a video of you doing the lesson in this article?
https://www.physicsforums.com/insights/explaining-rolling-motion/
This article was also super helpful as well. I would just like to see the demonstrations/experiments as well.
I am sure you will be able to find this derivation in a standard intermediate mechanics textbook. It's pretty ordinary stuff. Most introductory physics textbooks consider rotations about the center of mass and go from ##\frac{1}{2}\sum_i dm_iv_i^2## to ##\frac{1}{2}I\omega^2## through ##v_i^2 =\omega^2r_i^2## and then tack on the kinetic energy of the CoM but that is a bit of hand waving.
Sorry, there is no video of the lecture on rolling motion.
The point of doing a calculation is that you answer a question like "how come the equation works". And, yes, every point on a rigid body that is translating and rotating has a different velocity; and, yes, it's not obvious that this simplifies to KE of centre of mass plus rotational KE about the centre of mass. The only way to prove it is to do the calculation. That means ... mathematics!
  • · Replies 42 ·
