Calculating Moment of Inertia for Rotating Objects: A Kinetic Energy Problem
The moment of inertia for a spinning object with a radius of 0.5 m and mass of 6 kg, moving at a linear speed of 5 m/s and possessing a kinetic energy of 100 J, is determined to be 2 kgm². The calculation involves the equation K.E. = Kinetic energy of rotation + kinetic energy of translation. The correct approach requires understanding that the linear speed represents the speed of a point 0.5 m from the axis of rotation, leading to the conclusion that the moment of inertia is I = 2 kgm².
  • Understanding of rotational dynamics and moment of inertia
  • Familiarity with kinetic energy equations in physics
  • Knowledge of angular velocity and its relation to linear velocity
  • Basic algebra for rearranging equations
  • Study the relationship between linear speed and angular velocity in rotating systems
  • Explore the derivation of the moment of inertia for various shapes
  • Learn about fixed-axis rotation and its implications on kinetic energy calculations
  • Investigate the principles of conservation of energy in rotational motion
Students studying physics, particularly those focusing on mechanics, as well as educators and tutors looking for clear examples of moment of inertia calculations in rotational dynamics.
RoboNerd
  1. What is the moment of inertia of a spinning object of radius 0.5 m and mass 6 kg moving at 5 m/s, if it has a kinetic energy of 100 J?
    1. 1) 1 kgm2
    2. 2) 2 kgm2
    3. 3) 4 kgm2
    4. 4) 8 kgm2
    5. 5) 20 kgm2
[/B]
Hi everyone. I keep trying to solve this and I get the answer to be 0.5 kgm^2.
Obviously, this is not an answer. They say that the answer is 2).
Here's what I did:
(1 / 2) * m * v^2 + (1 /2) * I * omega^2 = 100.
(1 / 2) * 6 * 5^2 + (1 /2) * I * (v^2 / r^2)^2 = 100.
Rearrange to get I = (r^2 / v^2 ) * 50 = 0.5
Why do I not stack up with what the authors have written here? Thanks in advance for the help!
The statement of the problem is fuzzy. You can get answer (2) if you assume that the object is rotating about a fixed axis and assume that the 5 m/s represents the linear speed of a point located a distance 0.5 m from the axis of rotation.
OK, so I do not need to worry about it. Thanks a lot.
  • · Replies 21 ·
  • · Replies 16 ·
