How Does Kinetic Friction Affect Motion in a Pulley System?
The discussion centers on calculating the coefficient of kinetic friction (Uk) between block C and the table in a pulley system involving three blocks with masses 2M, M, and 2M. The system accelerates at 0.500 m/s². The calculations involve applying Newton's second law and analyzing forces acting on block C, leading to the conclusion that Uk = 0.449, which is a physically valid result as it is less than 1. The process outlined includes drawing free body diagrams and setting up equations for tension and friction forces.
  • Understanding of Newton's second law (F=ma)
  • Ability to draw and interpret free body diagrams
  • Knowledge of kinetic friction and its relationship to normal force
  • Familiarity with pulley systems and their dynamics
  • Study the principles of pulley systems in classical mechanics
  • Learn about the derivation and application of the coefficient of kinetic friction
  • Explore advanced topics in dynamics, such as systems with multiple blocks and pulleys
  • Investigate the effects of varying mass and acceleration on frictional forces
Physics students, mechanical engineers, and anyone interested in understanding dynamics and friction in pulley systems will benefit from this discussion.
lizette
There are 3 blocks on a table. One of the blocks, block C, is in the middle of the table with mass 2M. There are two pulleys on the edges of the tables. The pulley on the left is attached to block C and is attached to block A (which has a mass of M) such that it is hanging off of the pulley and is along the side of the table. The pulley on the right is also attached to block C and is attached to block B (Which has a mass of 2M) such that it is hanging off of the pulley and is along the right side of the table. They are released from rest and then accelerate with a mag of 0.500 m/s^2. What is the coefficient of kinetic friction (Uk) between the sliding block (block C, I am assuming - since it is attached on both sides by the rope holding the other two blocks that are hanging from the pulley) and the table?
I had 3 free body diagrams two were vertical (blocks A and B) and one was horizontal (block C)
Ta
Mg
Tb
2Mg
Ta--*--Tb (with forces of friction going towards the left since the right side has a block with mass 2M)
** also from the block there is a N force up and the Fg force down the block
Then I had:
A) Ta - Mg = ma = 0
Tb = ma + mg
B) Tb - 2Mg = 2Ma = 0
Tb = 2Ma + 2Mg
C) Tb - Ta - f = 2Ma
Tb - Ta - UkN = 2Ma
2Ma + 2Mg - Ma - Mg - UkMg = 2Ma
Uk = a/g + 1
Uk = 0.5/9.8 + 1 = 1.05102
Is my process correct?
Well, we have a problem when you get a u (I'm going to use a "u" for the coefficient of friction because it's similar to the greek letter mu) greater than 1. If you think about that it means that friction (remember force-friction Ff=u*Fn force normal for either static or kinetic) is exerting more force than the normal force, in other words, if you put a block on a table like this then stood it on its end the block would stick to the table instead of falling, which doesn't make physical sense.
Now looking at your equations A and B I see you set them equal to zero. But those blocks are moving, the B-block is falling and the A-block is rising and both have an acceleration a=0.5m/s^2 as does the C-block on the table. The string which is connecting them makes them move as a unit, not that string can push but gravity does the down and the string does the up.
So the thing here is to draw the picture and pick a block to work with. Since we want the coefficient of friction we chose block C. Now block C has three important forces acting on it, the force of block B falling (as I presume B, the heavier block, is the one causing the systems acceleration) to the right, the force of block A pulling to the left, slowing the fall, and the force of friction from the table which goes to the left because friction always resists motion. So, F=ma, and block C is undergoing acceleration of a=0.5m/s^2 (as are all the blocks) to the right so ma=(2M)*(0.5m/s^2). And the forces sum (with those in the direction of motion positive and those opposed to motion negative) to F=Fb (force by block B) - Fa - Ff (force of friction). then F=ma -> Fb-Fa-Ff=(2M)*(0.5m/s^2) Solve for Ff=Fb-Fa-Mm/s^2
Then substitute for the forces on the blocks, Fb would be the force due to gravity so Fb=2M*g and similarly Fa=M*g so Ff=2M*g-M*g-Mm/s^2=M*g-Mm/s^2=M(9.8m/s^2 - 1m/s^2)=8.8*Mm/s^2
Now kinetic friction relates to forces by uk=Ff/Fn so Ff=uk*Fn and we have from above Ff=8.8*Mm/s^2 so uk*Fn=8.8*Mm/s^2 and remember we're talking about block C here, all these forces were acting on block C so Fn=2M*g giving us uk*2M*g=8.8*Mm/s^2 -> uk=(4.4/g)m/s^2=.449 and the units canceled which is good and the number is less than one which is good and the mass variable M canceled which is good.
Your process appears to be correct. You have correctly identified the forces acting on each block and used Newton's second law (F=ma) to set up equations for each block. By solving for the tension in the ropes (Ta and Tb) and the force of friction (f), you were able to find the coefficient of kinetic friction (Uk) between block C and the table. Your final answer of 1.05102 seems reasonable, as Uk is typically between 0 and 1. Good job!
  • · Replies 23 ·
  • · Replies 21 ·
