Kinetics question in 2 dimensions
13 replies · 2K views
carolyn89012
A ball is hit by a golfer. The angle is 28 degrees, the velocity of the projectile is 16.0, the distance is 16.8m on horizontal. What is the velocity before impact on the ground of the ball?
2. Homework Equations
3. The Attempt at a Solution
Do you expect us to help you? What is giving you trouble?
Welcome to PF!
Hi carolyn89012! Welcome to PF! :wink:
Use the standard constant acceleration equations in the x and y directions separately …
what do you get? :smile:
Ok, so we have:
x=V_ox*t + 1/2 a_x t^2
16.8=14.18* t + 1/2 (0) t^2
16.8/14.18=t
t=1.14
However, a need the answer for y to continue, is that correct?
Do I solve for y distance with tan of y/x, since I know the angle?
Hi carolyn89012! :smile:
(try using the X2 and X2 tags just above the Reply box :wink:)
carolyn89012 said:
Ok, so we have:
16.8/14.18=t
t=1.14
Yes, that's right (btw, it's ok to just say "x = Voxt", without mentioning a, if ax = 0). :smile:
hmm … I honestly don't know what you do now …
the question doesn't seem to make sense as it is …
you've been given too much information, and it's contradictory. :frown:
Is that the complete question (eg, is the hole higher up than the golfer)?
Y will be 0 since the ball is colliding with the ground.
"hmm … I honestly don't know what you do now …
you've been given too much information, and it's contradictory. "
Yes, I agree thank you! There appears to be too much information. a_x=0, y=0, and t=1.14s after plugging in the numbers.
I, then, solved for V_x and V_y and then combined the two in solving for V_f using the the square root of the addition of (V_x)2 + (V_y)2. But don't know if any of this is correct.
Yeah, it was going to be a stupid question anyway …
golf balls have dimples which give them aerodynamic lift, so they don't follow the usual parabolic path. :rolleyes:
This question doesn't seem to have an answer, so just turn in anything. :smile:
Note that
[tex]V^{2}_{x} + V^{2}_{y} = V^{2}\sin^{2}(\theta) + V^{2}\cos^{2}(\theta) = V^{2} (\sin^{2}(\theta) + \cos^{2}(\theta) ) = V^{2}[/tex]
Using the trig identity sin^2(x) + cos^2(x) = 1
Interesting point!
A classmate and I were just trying to figure out how to calculate sin^2 or cos^2 on our calculators--couldn't figure out what to do, nor could our TA.
ok first get the time..
Δd= vot-1/2at2
16.8= 14.127t ( the acceration for the x coordinate is 0)
t= 1.189
now use a= vo+vf /2 <<<<<solve for the Vfy
-9.8= (7.51+x)/1.189
Vfy = -19.1622m/s
now u have to get the resultant
√(-19.16222+14.1272)
the answer is then -23.80m/s and at an angle of 53.601
hope this helps...
Am I missing something? This looks like a simple problem with a parabolic trajectory. There's been no talk of wind resistance, dimples or any x-axis acceleration in the problem statement. Therefore: wouldn't the landing be symmetrical to the takeoff? Why wouldn't the velocity on landing simply be 16 m/s at -28 degrees?
Oops, yes I was missing something. I forgot th 18m horizontal. I'm done for the day.
