KNCalculating Member Forces in Truss Structures
5 replies · 2K views · last reply
MMCS
Attached is a picture of the truss. I am trying to calculate the member forces.
I know a moment is = force * perpedicular distance, but in this case, for example, if i am taking moments about A, Would the equation be
-(1*2KN)+(1*c) = 0
or using an alternative perpedicular distance
-(2.4*2KN)+(0.8*c) = 0
For my preliminary working, assuming i have used correct perp distance i have
ƩFx = 0
ƩFy = 0
ƩMoments about a point = 0
Ay + By - 2KN = 0
Momments about A = -(2KN * 2.4) + 1*ReactionC = 0
-4.8KN = reactionC
Sub into first eq
Ay +(-4.8) -2 = 0
Ay = 6.8
To find out the reaction in member AB
I have
6.8 - Tab Cos(tan-10.8/1) = 0
Tab = 6.8/Cos(tan-10.8/1) = 8.738
I have the answer to be 2.56
  • Truss diagram with joints labelled A, B, C, D and E; A is a pin support on the left, C a pin support at the bottom, a 2kN downward load at E, and dimensions of 1m vertical and 0.8m horizontal spacings.
In taking moments, the 2kN force has the same direction as the vertical distance on 1m, so its moment will be 0. If you get confused, you can always calculate M = r x F, where x is the cross product operator.
Im don't quite understand sorry, i would understand if the force was acting through the point i am taking momoments about but how can the 2KN force x distance away not cause a moment
Using the value of of 4.8 but the same working i end up with a final equation of
2.8/cos(38.66) = 3.59
Ok i realize where my confusion was on this problem thanks for your help
