Laminate properties (0/90) and (0/+45/-45/90)
  • Thread starter Thread starter jblakes
    Properties
The discussion revolves around the properties of two different laminate stacking sequences: (0/90) and (0/+45/-45/90). Participants explore the results of tensile and three-point bend tests, comparing ultimate tensile strength (UTS), elastic modulus, flexural strength, and toughness. The conversation seeks to understand the underlying reasons for the observed differences in mechanical properties based on the stacking sequences.
  • One participant notes that the (0/90) laminate exhibits higher UTS, elastic modulus, and flexural strength compared to the (0/+45/-45/90) laminate, which has a higher flexural modulus but similar toughness.
  • Another participant questions whether analyses have been conducted to determine stresses within individual plies and interlaminar shear stresses.
  • A participant expresses uncertainty about how the stacking sequence affects properties and seeks clarification on whether the first laminate is a symmetric cross ply and the second a quasi-isotropic laminate.
  • There is a suggestion that the first laminate may not be symmetric but could be treated as such under certain loading conditions, emphasizing the need for a better understanding of laminate theory to analyze stresses within each layer.
  • A reference to a book by Byron Pipes is provided as a resource for understanding laminate theory.
Participants do not reach a consensus on the reasons behind the differences in properties between the two laminates, and there are varying interpretations of the stacking sequences and their classifications.
Participants express limitations in their understanding of laminate theory, which may affect their ability to analyze the mechanical properties and stresses within the laminates. There is also a lack of detailed analysis regarding interlaminar shear stresses.
jblakes
Evening all,
im hoping somebody can help or point me in the right direction.
We have tested these two laminates, one tensile and other three point bend test. The (0/90) has a higher uts, elastic modules, and flexure strength.
(0/+45/-45/90) has a higher flexural modulus. Both roughly same toughness.
I can seem to find anything that clearly explains why this is. To me the (+45/-45) one should have have higher uts as its got two more plies to add strength, but then read somewhere about it fails as more angles means it fails through midplane.
Can somebody explain this and give a resource to read?
Kind regards
Andy
Have you carried out analyses to determine the stresses within the individual plies, and the inter laminar shear stresses?
No, we have just performed a tensile and 3point bend test on a
(0/90/0/90/0/90/0/90) 8layers
(0/45/-45/90/90/-45/45/0) 8layers,
the question i need to answer is how the stacking sequence effects the properties. I've tried reading laminate theory but just don't seem to understand. Am i right in thinking the first one is a symmetric cross ply and the second one is a quasi-isotropic laminate?
The second is what I would call a symmetrically stacked laminate. The first isn't, but it can probably be treated as such if the loading is along the principal directions of the reinforcement. Before you start trying to deal with something like this, you need to develop some understanding of laminate theory. That way you can determine the stresses within each layer. See book by Byron Pipes.
21K
  • · Replies 0 ·
  • · Replies 25 ·
