- 814
To begin: This is not a question, but an anecdote.
The other day my wife called to me from the floor above: "Svein, there is no light". OK, I checked the fuses, and sure enough one fuse had tripped. I resat it, only to hear "Svein, it is blinking!". I went up to see what she meant by that and, sure enough, one ceiling light was blinking like a distress signal. "OK" I said. "Turn it off, and I will take a look". "It is turned off, but it still blinks!" So I disconnected the lamp and started trying to find out what had happened. It turned out that she had sprayed the lamp with a cleaning solution in order to clean it for Christmas.
Thinking about it, I arrived at a conclusion. Soapy water plus dust makes a high impedance resistor. The metal in the lamp was grounded. The light switch was a one-pole type, so one lead was "live". Thus the LEDs were able to draw a small current. This current apparently charged a capacitor in the LEDs and when the capacitor voltage passed a threshold, the LEDs turned on and promptly discharged the capacitor. After this behavior had gone on for a minute, the RCD tripped and the whole floor went dark.
I took the lamp apart and saw that the voltage distribution center was fairly wet (as I had suspected). Worse, the guys in the lamp factory had obviously discovered some bad insulation somewhere and had wrapped the distribution points in electrical tape. When I touched the tape, it promptly fell off. Some strong language followed, but I fetched some shrink tubing and a heat gun, dried out the thing and put shrink tubing over the wires. Case closed.
