Lamp Brightness in Parallel Circuit
2 replies · 5K views · last reply
calculator20
I'm looking at a problem where a battery of negligible internal resistance is connected to two lamps L and N in parallel with each other, then through in series to a 3rd lamp M. The question asks if the filament of one of the lamps in parallel N breaks then what happens to the brightness of the remaining lamps L and M.
The choice was
Lamp L , Lamp M
A) stays the same , decreases
B) increases , stays the same
C) increases , decreases
D) decreases , increases
The markscheme says its C. I understand that L would increase as it no longer shares its current but I thought the answer would be B as I didn't think M would be affected? Where am I going wrong?
Imagine them all as equal resistors 'R'.
If you have two resistors in parallel what is the total resistance ?
If the pair and M are in series what is the voltage drop across the pair and across M?
Now if one breaks, you have the same resistance L and M in series.
What happens to the voltage drop across M?
Think equivalent resistance before the break and current passing through the resistances, and then again after the break.
Before (R*R/R+R)+ R
After R+ R
substitute a value of your choice for all resistances in the circuit, and see how the current changes in both L and M
