Laplace transform of step function
The Laplace transform of the function g(t), defined as 0 for 0<t<1 and t^2 for t>1, can be expressed using the unit step function as g(t) = t^2*u1(t). The transformation involves applying the shifting property, leading to the evaluation of L(f(t)) = e^(-s) * L(t^2 + 2t + 1). A suggested approach to simplify the function is to let u = t - 1, allowing for the expansion of t^2 into (u + 1)^2. To verify the result, evaluating the integral from 1 to infinity of t^2 e^(-st) is recommended.
ElijahRockers
Find laplace trasform of g(t)
g(t) = 0 for 0<t<1, t^2 for t>1
So this can be re-written as g(t) = t2*u1(t), where u is the unit step function.
By using the fact that L(uc(t)f(t-c)) = e-csF(s) i am trying to take the laplace...
So in this case, f(t-c) = t2 ... so then does f(t) = (t+1)2?
if so, I get L(f(t)) = e-s*L(t2+2t+1) which I can evaluate to get
e-s(2/s3 +2/s2 +1/s)
but I'm not sure if that whole shifting function thing I did is correct, specifically, f(t)=(t+1)2. the book's example uses a trig function that is already shifted so I am a little unsure of how to proceed
Thanks.
Probably the easiest way to rewrite the function is to let u=t-1, so that t=u+1 and
$$ t^2 = (u+1)^2 = (t-1)^2 + 2(t-1) + 1$$ which is what you had. You could also check your answer by evaluating the integral
$$\int_1^\infty t^2 e^{-st}\,dt$$ and see if you get the same answer.
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
