Can the Laplace Transform Be Determined for Specific Functions?
The discussion centers on two questions regarding the Laplace transform of specific functions. For the first question, it is concluded that the function f(t) = e^t/(t^4-1) does not have a Laplace transform for sufficiently large real values of s, as it does not meet the criteria of being of exponential order. In the second question, participants explore whether a function can exist such that its Laplace transform equals e^s, with some suggesting that no such function exists. The conversation emphasizes the importance of understanding the conditions under which Laplace transforms are defined and the behavior of functions at large t. Overall, the thread highlights the complexities involved in determining the existence of Laplace transforms for specific functions.
yy205001
Can people help me on these two questions, please.
Q1)
Does f(t) have a Laplace transform F(s) for sufficiently large real value of s, where
f(t) = et/(t4-1).
Q2)
Either find a function f(t) for which F(s) = L{f(t);t→s} = es, or explain why no such function f(t) exists.
For Q1:
Since there is no such a real constants K s.t f(t)≤ K*f(t), therefore f(t) is not of exponential order. So, Laplace transform does not exist.
For Q2:
My guess for the answer is No but I can't explain it mathematically.
Any help is appreciated!
Start out by writing out the definition of the laplace transform explicitly in terms of the unknown function ##f(t)##. Knowing that you want the integral to evaluate to ##e^s##, you should be able to see what kind of function would be necessary to satisfy the equation. (*Hint: it's the kind of "function" you would see in a time shift*)
So, i start at ∫e-stf(t)dt from 0 to ∞ and set it to es?
Q1)
f(t) = et/(t4-1).
Q2)
For Q1:
This can't be correct. f(t) ≤ K f(t) is satisfied by K=1. What did you really mean to say?
For Q2:
Regarding Q2: Yup! It's almost the definition of the function I'm thinking of itself: have you seen it before?
Except there's a crutial part to the limits of your integral that you would have to pay close attention to in order to understand whether the function is actually a viable solution...
That is to say, you can think about what the function would need to be, and then perhaps why such a function can or can't exist with respect to the Laplace transform
vela:
But when happen if t4<1? Then K=1 does not satisfy the inequality.
PhysicsandSuch:
So i need to make assumption for Question 2?
yy205001 said:
vela:
PhysicsandSuch:
I don't think you have to make any assumptions, just examine closely for the necessary functional form and whether it's possible given the domain of the integral...
What did you have in mind? Maybe write out your line of thinking so I can get a better idea of where you are getting stuck...
I don't think you're reading what you wrote. Surely you agree that f(t) = f(t) for all t. If K=1, then f(t) = K f(t). So f(t) ≤ K f(t) for all t.
Q1)
f(t) = et/(t4-1).
Q2)
For Q1:
For Q2:
For Q2: have you tried using Mellin's formula for the inverse Laplace transform of F(s)? That formula states that
f(t) = {\cal{L}}^{-1}(F)(t)<br /> = \frac{1}{2 \pi i} \lim_{T \to \infty} \int_{\gamma-iT}^{\gamma+iT} e^{st} F(s) \, ds,
where the integration is done along the vertical line ##\text{Re}(s) = \gamma## in the complex s-plane, with ##\gamma## lying to the right of all singularities of F(s). For the case of F(s) = e^s you can take γ = 0 and just do the integral. Do you get a finite result?
vela:
I think I wrote something wrong above, it should be abs(f(t)) ≤ K*eσt. So, if there exist real constants K and σ such that for all sufficiently large values of t, the inequality holds then Laplace transform exists.
PhysicsandSuch:
I think the convolution integral equation might help! I will try this out first.
Ray Vickson:
Um..I don't think I have not gone this far yet in my course. So, this might not be the way to get the answer.
yy205001 said:
vela:
I thought so, but I wasn't sure what criterion you were referring to.
This particular function satisfies the above condition because it only cares about what happens at large t. In other words, the function goes to 0 fast enough so as not to cause problems with convergence as you integrate out to ∞.
You need to find a different reason for why F(s) doesn't exist.
