Laplace transformation initial value problem
6 replies · 5K views
quietriot1006
I need to use the Laplace transformations to solve this IVP
y'-y=2cost(5t) , y(0)=0
I separated the question until the point
Y(s)=(2s)/(s^2+25)(s+1)
and then
2s=A(s+1)+B(s^2+25)
I get the answer for B=-(1/13) and i just want to know how to get A and if i am doing it right so far. ASAP would be great. Thanks.
and then
2s=A(s+1)+B(s^2+25)
It would be helpful to see your work in how you got to the Y(s) equation. Also, I assume that the (s + 1) factor is in the denominator, but how you wrote it one could reasonable assume it is in the numerator.
For the 2nd equation above, did you separate the rational expression as A/(s^2 + 25) + B/(s + 1)? If so, that's incorrect. The first expression should be (As + B)/(s^2 + 25), and the other C/(s + 1)
I messed up the first problem, there is no t after cos. This is how the problem is written.
y'-y=2cos(5t) , y(0)=0
Here is my work from the beginning:
sY(s)-0+Y(s)=(2s)/(s^2+25)
Y(s)=(2s)/((s^2+25)(s+1))
2s=((As+B)(s+1))+(C(s^2+25))
Let s=-1 and then i solve for C which comes out to equal (-1/13). And then I get stuck at A and B. I looked at what you said and you are right and i fixed that but I am still stuck.
Yes I should. Because of the minus from the initial problem. Thanks for that one. So
C=(1/13) with no minus sign. What about the rest? What number can I choose for s that will cause (s^2+25) to equal zero and then to get A and B?
Cool! i think i got it.
y(t)=(-1/13)cos(5t)+(25/13)sin(5t)+(1/13)e^t
Is this right?
