How do I use integration by parts to find the Laplace transformation of tsin(t)?
The Laplace transformation of the function f(t) = tsin(t) can be effectively computed using integration by parts (IBP) and complex analysis. The integral ∫tsin(t)e^(-st)dt can be approached by first rewriting sin(t) in terms of complex exponentials, leading to the integral ∫te^(-st+i t)dt. A common method involves performing IBP twice and solving for the original integral. Additionally, utilizing the relationship ∫_0^∞ t sin(t) e^(-st) dt = -d/ds ∫_0^∞ sin(t) e^(-st) dt simplifies the process significantly.
  • Integration by Parts (IBP) technique
  • Understanding of Laplace transforms
  • Complex exponential functions
  • Trivial integrals involving sine and exponential functions
  • Learn advanced techniques in integration by parts for complex functions
  • Study the properties of Laplace transforms in detail
  • Explore the relationship between trigonometric functions and complex exponentials
  • Investigate the application of differentiation under the integral sign
Students and professionals in mathematics, engineering, and physics who are working with Laplace transforms and integration techniques, particularly those dealing with complex functions and differential equations.
bmb2009
Find the Laplace transformation of the following function by using iterations of integration by parts:
f(t) = tsin(t)
I know how to do integration by parts (as learned in calculus) but have never seen a funtion that has dependence on t in three places ie. definition of laplace transform is ∫f(t)e^(-st)dt which for this problem would go to... ∫tsin(t)e^(-st)dt...how would I go about starting this? thanks
f(t) = tsin(t)
You could undoubtedly do it if it were just ##t## times an exponential. Since ##\sin t## is the imaginary part of ##e^{it}##, try$$
\int_0^\infty te^{(-s+i)t}~dt$$ and take the imaginary part of the answer.
The complex integral approach is completely correct but you would want to use the fact that
sin(t)= (eit- e-it) / 2i
Just to clarify on my notation ∫UdV = UV + ∫Vdu
So, if we let U= t and dV= sint(t)e^st all we have to do is figure out the integral of dV.
This is another common problem done in integral calculus on its own. The approach is to do IBP twice and return with the original integral so that you can solve for it in a less than kosher way. Just remember to keep the limits 0,∞ throughout the problem in the appropriate places.
For your convenience if dV= sin(t) e^st, then V= 1/(1+s2). This is only valid for the limits of integration 0, ∞.
Another trick is to use
\int_0^{\infty} \mathrm{d t} t \sin t \exp(-s t)=-\frac{\mathrm{d}}{\mathrm{d} s} \int_0^{\infty} \sin t \exp(-s t),
which is a trivial integral, using the exponential form of the sine function.
\int_0^{\infty} \mathrm{d t} t \sin t \exp(-s t)=-\frac{\mathrm{d}}{\mathrm{d} s} \int_0^{\infty} \sin t \exp(-s t)\mathrm{d t},
Fixed (missing a dt in the last integral).
Or you could just try breaking it up as u=t sin t and dv=e-st dt.
