Laplace Transformations Step Functions
7 replies · 2K views · last reply
Mikesgto
The attachment is the problem.
I understand how to go about solving the laplace transformations but I have no idea how to start with the Heaviside functions for the 5t and the 30. What I got was 5t+30U6(t) but it turned out to be wrong. Any help would be greatly appreciated.
That's close. If t=7, the forcing function should be equal to 30, but your expression would give 5(7)+30U6(7) = 35+30 = 65. Can you see why it's wrong and how to fix it?
5t-5U6(t)(t-6)
I got this one after a ton of work, but I am failing to grasp the concept going behind this.
You can look at it this way. You only want the 5t term to contribute between t=0 and t=6, so after t=6, you have to subtract out 5t to cancel the other 5t term:
F(t) = 5t U0(t) + 30 U6(t) - 5t U6(t)
(Often, it's understood that the input is 0 for t<0, so you don't write the U0(t) in explicitly.) When t>6, the first and last terms cancel, and you're just left with F(t)=30.
You can also look at it like this, which is the way I prefer. If you rearrange the terms slightly, you can write
F(t) = 5t (U0(t) - U6(t)) + 30 U6(t)
The factor U0(t)-U6(t) is equal to 1 between t=0 and t=6 and is equal to 0 everywhere else, so it turns the 5t term on between t=0 and t=6 and disables it for the other times.
ok, so the next problem i have is attached and the solution i came up with is
3t-3tU9(t)
Am I on the right path there?
Yup, that's right.
Thanks so much for all the help. The next part of my solutions are finding out F(s). Do I treat the -3t attached to the U9(t) as my f(t)?
I'm not sure what you're asking. It might help if you show us your calculations.
