Laplace Transformations Step Functions
The discussion revolves around Laplace transformations involving step functions, specifically Heaviside functions. Participants are exploring how to correctly express piecewise functions using these transformations.
  • Mixed
  • Participants are attempting to express functions involving Heaviside step functions and are questioning their initial formulations. There is exploration of how to correctly account for contributions of terms over specific intervals.
Some participants have provided guidance on how to structure the functions using Heaviside functions, while others are still clarifying their understanding of the concepts involved. There is an ongoing exploration of different interpretations and approaches to the problems presented.
Participants are working with specific constraints related to the definitions of the functions and the intervals over which they apply, as well as the implications of using Heaviside functions in their expressions.
Mikesgto
The attachment is the problem.
I understand how to go about solving the laplace transformations but I have no idea how to start with the Heaviside functions for the 5t and the 30. What I got was 5t+30U6(t) but it turned out to be wrong. Any help would be greatly appreciated.
That's close. If t=7, the forcing function should be equal to 30, but your expression would give 5(7)+30U6(7) = 35+30 = 65. Can you see why it's wrong and how to fix it?
5t-5U6(t)(t-6)
I got this one after a ton of work, but I am failing to grasp the concept going behind this.
You can look at it this way. You only want the 5t term to contribute between t=0 and t=6, so after t=6, you have to subtract out 5t to cancel the other 5t term:
F(t) = 5t U0(t) + 30 U6(t) - 5t U6(t)
(Often, it's understood that the input is 0 for t<0, so you don't write the U0(t) in explicitly.) When t>6, the first and last terms cancel, and you're just left with F(t)=30.
You can also look at it like this, which is the way I prefer. If you rearrange the terms slightly, you can write
F(t) = 5t (U0(t) - U6(t)) + 30 U6(t)
The factor U0(t)-U6(t) is equal to 1 between t=0 and t=6 and is equal to 0 everywhere else, so it turns the 5t term on between t=0 and t=6 and disables it for the other times.
ok, so the next problem i have is attached and the solution i came up with is
3t-3tU9(t)
Am I on the right path there?
Yup, that's right.
Thanks so much for all the help. The next part of my solutions are finding out F(s). Do I treat the -3t attached to the U9(t) as my f(t)?
I'm not sure what you're asking. It might help if you show us your calculations.
