Laplace Transforms Involving: Unit-Step, and Ramp Functions
12 replies · 5K views · last reply
ConnorM
Here is an imgur link to my assignment: http://imgur.com/N0l2Buk
I also uploaded it as a picture and attached it to this post.
[itex]u_c (t) =<br /> \begin{cases}<br /> 1 & \text{if } t \geq c \\<br /> 0 & \text{if } t < c<br /> \end{cases}[/itex]
Question 1.1 -
[itex]L[tu(t)] = \int_0^∞ tu(t)e^{-st} \,dt[/itex]
Using the definition of the step function, [itex]t \geq 0, u(t) = 1[/itex]
*Is it right to assume that [itex]c = 0[/itex]?*
[itex]L[tu(t)] = \int_0^∞ t(1)e^{-st} \,dt[/itex]
[itex]L[tu(t)] = \int_0^∞ te^{-st} \,dt[/itex]
[itex]L[tu(t)] = 1/s^2[/itex]
I'm not sure if this is correct. Should it be solved using the rule, [itex]L[tf(t)] = -F'(s)[/itex]
Question 1.2 -
Let [itex]r_1 (t), r_2 (t)[/itex] be the two ramp functions
Let [itex]u_1 (t), u_2 (t)[/itex] be the two unit-step functions
[itex]r_1 (t) =<br /> \begin{cases}<br /> t & \text{if } 0 \leq t < 1<br /> \end{cases}[/itex]
[itex]r_2 (t) =<br /> \begin{cases}<br /> t+1 & \text{if } 1 \leq t < 2<br /> \end{cases}[/itex]
[itex]u_2 (t) =<br /> \begin{cases}<br /> 3 & \text{if } 2 \leq t < 4<br /> \end{cases}[/itex]
I'm not quite sure what to do for the unit-step functions. Could someone help me figure out what they should be?
  • Graph of y(t) against t: piecewise linear, rising from 0 to 1 at t=1, jumping to 2 at t=1, rising to 3 at t=2, flat at 3 until t=4, then dropping to 0 at t=4. Printed problem text above lists Problems 1.1 and 1.2.
Your transformation is correct. For the second part, I do not think you have done what was intended. You are supposed to write the function as a linear combination, not as different expressions in different regions.
So would it be something like,
Let [itex]y(t)[/itex] be the function on the graph that I am trying to recreate.
** Is this true, [itex]r(t) = tu(t)[/itex]? **
So,
[itex]y(t) = tu(t) - (t+1)u(t-1) - 3u(t-2)[/itex]
Although I still don't know what the second unit-step function should be?
Have you tried plotting the function you gave? How does it differ from the one you should find?
ConnorM said:
$$y(t) = tu(t) - (t+1)u(t-1) - 3u(t-2)$$
Try plotting the function g(t) = u(t-1)-u(t-2). You should see it's a pulse. Now consider what you'll get if you multiply g(t) by some function. Try plotting the function f(t) alone and the product f(t)g(t). For instance, try it with f(t) = t2. Do you understand the effect of multiplying by g(t) on the graph?
I tried plotting it and from what I see it's not similar at all.
So multiplying f(t) by g(t) gives me a point on that function?
Which function? Which point? Can you elaborate?
So for g(t) that you suggested it gave a pulse at (1,1), then when I plotted [itex]f(t) = t^2[/itex] I got a parabola. When I multiplied f(t) by g(t), I got a pulse again at (1,1).
I suggest that you think along the following lines:
  • What happens when you pass the step of a step function? What changes? Where do these changes occur for the sought function?
  • What happens when you pass the base of a function of the form ##(t-a) u(t-a)##? Where do these changes occur for the sought function?
I don't think you plotted g(t) correctly then. I'm not sure what you mean by a pulse at (1,1). I've attached a plot of what you should've gotten.
  • Graph of a horizontal line segment at height 1, spanning x from 1 to 2, with y-axis ticks from 0.2 to 1.0 and x-axis from -1 to 4.
So I did some work with graphing the equations and I think this is the right one,
[itex]y(t) = tu(t) + u(t-1) - (t-2)u(t-2) - 3u(t-4)[/itex]
Let me know if this latex is working or not, I'm on my phone and can't see if it's showing up correctly!
Looks reasonable.
