Laser Cutting Machines: What Cuts Steel?
Laser cutting machines utilize high-power laser beams, primarily generated from gas lasers, to cut through materials like steel. The cutting process involves light that melts or vaporizes the material, creating precise cuts while leaving a heat-affected zone. These machines require a pure gas atmosphere to maintain high power output, as impurities can disrupt the laser's effectiveness. Additionally, assist gases, commonly nitrogen, are used to remove molten material and prevent oxidation during cutting. The technology demonstrates remarkable efficiency and precision, even when cutting other materials like wood with minimal burning.
Dav333
Just curious after watching some lasers cutting 5mm thick steel sheets very fast, what is exactly cutting the steel?
Is it just a laser beam? Light only? The machines run on bottles of gas, so if not, what exactly is the beam made of?
thanks
Science news on Phys.org
Yes, the material is cut using the laser beam. Light only. The used lasers are high power gas lasers. Also see http://en.wikipedia.org/wiki/Laser_cutting
To keep up the high power output you need a rather pure gas atmosphere. Sadly you can't just seal the resonator tube and let it be, because the laser beam starts reactions disassociating the gas molecules and leading to impurities. Depending on the machine design, this lasing gas is either continually replaced or replaced after a certain period of time.
The gas tubes you have seen are likely either used for that purpose or for assist gas. The assist gas is blown on the sheet to remove molten material and speed up the production. Nitrogen is the most common assist gas out there, as it also inhibits oxidization along the edges.
thanks. further reading: :on the principle of converting electrical energy to a laser light output with the gas:, understand more now.
amazing the end result is just light that cuts so fast & so precise. Even cut wood & hardly burned it. The nozzles are super high heat resistance.
The light beam melts/vapourises the material and that's what does the cutting, like any heat cutting system it'll leave a heat affected zone around the cut.
