Laser light interference on liquid metal. why?
The discussion revolves around the phenomenon of laser light interference observed when reflecting laser light off liquid gallium metal. Participants explore the nature of the interference patterns produced, questioning whether they are indeed due to interference or other optical effects related to the surface characteristics of the liquid metal.
  • One participant describes using laser light to visualize tiny movements in liquid gallium, noting the presence of interference patterns that differ from reflections off a mirror.
  • Another participant questions the nature of the observed patterns, suggesting they may be due to focusing and defocusing effects from surface irregularities rather than true interference.
  • A different participant asserts that the distinct lines and dot patterns observed are evidence of light interference, emphasizing the regularity of the patterns.
  • Another hypothesis suggests that impurities in the gallium could create a surface texture that allows multiple reflections to contribute to the observed pattern.
  • A request for additional information, including a photo and details about the experimental setup, is made to better understand the diffraction pattern and its features.
Participants express differing views on the nature of the observed patterns, with some supporting the idea of light interference while others propose alternative explanations related to surface irregularities. No consensus is reached regarding the cause of the patterns.
Participants note the potential influence of surface impurities and the angle of incidence on the observed patterns, but the discussion remains open regarding the exact mechanisms at play.
bizzder
I wanted to make tiny movements of the Earth visible by reflecting laser light off liquid gallium metal. It did produce nice reflections on my wall, showing dramatic wobbles of very tiny movements of the liquid gallium. It did however produce light interference patterns which I cannot explain. Simply reflecting the laser light on the wall with a mirror doesn't produce this.
How is it that a metal can produce this? Metals are very nice examples of how it's combined particles behave individually because of purity (through amplification?) Is this a good example of the laser light interacting with gallium atoms on a quantum scale? How does this work? I think it's quite interesting!
Yes I agree, it's quite interesting! Is it really an interference pattern? You know, if you reflect light off an irregular surface like the surface of water, you'll see a moving pattern of light and dark too, but this is focusing and defocusing caused by ripples on the water and changing curvature of the surface. I'm wondering if that's what you're seeing here.
They are very distinct and well defined lines, with perfect spacings between. At some points, these lines overlap, and create a dot pattern, which I think it's proof that his is light interference!
Perhaps impurities in the Gallium are causing a microscopic lumpiness in the surface of the droplet? That would give several reflections a chance to be cast onto the one point on your wall.
If this is so you might be able to find a way to push the impurities around and so change the pattern displayed on your wall.
Can you post a photo? And give some indication of the angle of incidence between the beam and the surface, as well as the distance to the wall? That should allow you to figure out the dimension of the features that are producing the diffraction pattern.
  • · Replies 0 ·
  • · Replies 71 ·
10K
