Laser power in optical tweezers
MadMarvin
Hi,
I'm currently recalibrating an optical tweezer for my undergraduate thesis. The alignment did turn out well so far but I'm a little bit concerned about the power loss within the microscope (here's a picture of the relevant part, without prisms).
I read in a paper that 20 to 100mW are sufficient for most basic applications. I measured the power at different points (the condenser is not fully aligned yet):
Before TL2: 105 mW
After L_BFP: 10-20 mW, depending on how well the immersion oil works.
Is that enough? I use a DIC microscope, so the light passes two DMs, two prisms, objective, condenser and their respective apertures. The beam has been expanded to roughly 3,5mm, so I did not expect the power after L_BFP to be very high. But 10 mW seems too low.
Also, I haven't inserted the quadrant photo diode yet. My advisor thinks it should be placed a good deal before the focal point of L_BFP - shouldn't it be placed a little bit behind?
My first instinct would be to make sure that the NAs of the various lenses are matched properly. If you propagate from high NA to low NA you will lose a chunk of power.
Claude.
Make sense, problem is: I do not even know the manufacturers of all the parts, let alone the properties of each one. I do not mind the power loss as long as the back focal plane interferometry still works so I will have to try that out, first (the diode is being repaired right now).
Anyway, thanks for your advice. Could someone elaborate on my last question, please?
